Does "sudo apt-get remove ros-cturtle-ros" also removes other packages in my home folder? If not, could I just manually delete them or is there a recommended method?
Originally posted by Homer Manalo on ROS Answers with karma: 475 on 2011-02-27
sudo apt-get remove ros-cturtle-ros will remove all cturtle packages in /opt/ros but not do anything in your home directory.
To remove things from your home directory rm -rf ~/ROS or whatever path you want to remove will work. Or, if you wish, you can delete the directories from a file browser GUI.
Note: There's no undo for rm so make sure you get the path right.
Originally posted by tfoote with karma: 58457 on 2011-02-27
