When creating a URDF file for a robot with a head on a pan and tilt mechanism, whenever I try to use a joint type "continuous" or "revolute" in a manner similar to that shown in the tutorials the model is displayed within Rviz as a disorganized jumble. If I change the joint type to "fixed" then the model displays normally. The model also seems to check out ok using check_urdf, and no URDF errors show up when Rviz is loading. This seems to be a bug, since the same thing happens with the tutorial file 06-flexible.urdf
I'm using the current cturtle full binary installation on Ubuntu 10.10.
Originally posted by JediHamster on ROS Answers with karma: 995 on 2011-02-19
