gazebo7
is an official package in Ubuntu Xenial 16.04. The tutorial says that it should be automatically installed when you need to install ROS packages. So a simple apt-get install ros-kinetic-desktop-full
should just work.
If you want to get the latest gazebo7
then you can follow these instructions to proceed step by step. Basically add the OSRF repository together with the key.
(edited after comment)
Back to the original question of getting the latest gazebo7
version after installing ros-kinetic-desktop-full
and got 7.0.0
: steps should be the same as detailed in the step by step tutorial basically add the osrfoundation.org repository and run apt-get install gazebo7
. That should give you the following output:
root@f8f9dfa4bc91:/# apt-get install gazebo7
Reading package lists... Done
Building dependency tree
The following additional packages will be installed:
gazebo7-common gazebo7-plugin-base libbullet-dev libbulletsoftbody2.83.6 libgazebo7 libgazebo7-dev
Suggested packages:
gazebo7-doc
The following NEW packages will be installed:
The following packages will be upgraded:
gazebo7 gazebo7-common gazebo7-plugin-base libgazebo7 libgazebo7-dev
Do you want to continue? [Y/n]
Get:1 http://archive.ubuntu.com/ubuntu xenial/universe amd64 libbulletsoftbody2.83.6 amd64 2.83.6+dfsg-3 [104 kB]
Get:2 http://archive.ubuntu.com/ubuntu xenial/universe amd64 libbullet-dev amd64 2.83.6+dfsg-3 [243 kB]
Get:3 http://packages.osrfoundation.org/gazebo/ubuntu-stable xenial/main amd64 gazebo7 amd64 7.16.0-1~xenial [2338 kB]
Get:4 http://packages.osrfoundation.org/gazebo/ubuntu-stable xenial/main amd64 libgazebo7-dev amd64 7.16.0-1~xenial [615 kB]
Get:5 http://packages.osrfoundation.org/gazebo/ubuntu-stable xenial/main amd64 gazebo7-common all 7.16.0-1~xenial [40.1 MB]
Get:6 http://packages.osrfoundation.org/gazebo/ubuntu-stable xenial/main amd64 gazebo7-plugin-base amd64 7.16.0-1~xenial [945 kB]
Get:7 http://packages.osrfoundation.org/gazebo/ubuntu-stable xenial/main amd64 libgazebo7 amd64 7.16.0-1~xenial [6390 kB]
Originally posted by Jose Luis Rivero with karma: 1485 on 2020-02-03
Comment by TorontoRoboticsClub on 2020-02-10:
When I installed Kinetic, the version that came with it was 7.0, and I jumped through hoops to get 7.16 working (which is where this question came from). first I uninstalled gazebo7*, then I installed gazebo7-common for 7.16, then I did run the apt-get install ros-kinetic-desktop-full
and everything worked. The only problem is the 30 other commands that may have done something useful. My conclusions is it's possible to delete 7.0 and reinstall 7.16. Good luck....
