I tried to solve below question by Edx course. One part of the requirement was to assign frames and find the DH parameters of the given robot manipulator. I assigned the x and z axis as below and find the DH parameters like that:
I think I assigned axis correctly. Especially X2, because this one that make the problem. X2 can be both like in the picture and also upward, because in both of them it is perpendicular to both Z2 and Z1. However, when I did like that the answer became wrong. However, when I took the X2 as upward, the answer became correct. It is interesting for me, why X2 has to be upward while it also can be like in the picture I showed? Thank you very much :)
