I am trying to launch a simulation in Gazebo through ROS2 and I keep getting an error message stating that 'NoneType' object has no attribute 'get_launch_arguments_with_include_launch_description_actions'
. I've made two launch files through following a tutorial, but I've seen many people make do with just one launch file (perhaps you only need one?). Anyways, here are my two launch.py files:
# room.launch.py
#!/usr/bin/python3
import os
from ament_index_python.packages import get_package_share_directory
from launch.actions import DeclareLaunchArgument
from launch.actions import IncludeLaunchDescription
from launch.launch_description_sources import PythonLaunchDescriptionSource
pkg_name = "gazebo_simcontrol"
world_file = "room.world"
pkg_gazebo_ros = get_package_share_directory(pkg_name)
pkg_intro = get_package_share_directory(pkg_name)
# launch Gazebo by including its definition
gazebo = IncludeLaunchDescription(
PythonLaunchDescriptionSource(
os.path.join(pkg_gazebo_ros, 'launch', 'gazebo.launch.py'),
# load the world file
world_arg = DeclareLaunchArgument(
'world',
default_value=[os.path.join(pkg_intro, 'world', world_file), ''],
description='SDF world file')
return LaunchDescription([
gazebo,
world_arg
and then my second launch.py, named gazebo.launch.py:
#!/usr/bin/python3
import os
import sys
import rclpy
from gazebo_msgs.srv import SpawnEntity
package_name = 'gazebo_simcontrol'
def main(args=None):
rclpy.init(args=args)
node = rclpy.create_node('minimal_client')
cli = node.create_client(SpawnEntity, '/spawn_entity')
sdf_file_path = (os.path.join(get_package_share_directory(package_name), 'urdf', 'simpleMotor.urdf')),
model = open(sdf_file_path[0], 'r').read()
print("MODEL %s" %model)
req = SpawnEntity.Request(
name = "simpleMotor",
xml = model,
robot_namespace = "motor",
reference_frame = "world",
while not cli.wait_for_service(timeout_sec=1.0):
node.get_logger().info('service not available, waiting again...')
future = cli.call_async(req)
rclpy.spin_until_future_complete(node, future)
if future.result() is not None:
'Result ' + str(future.result().success) + " " + future.result().status_message)
else:
node.get_logger().info('Service call failed %r' % (future.exception(),))
node.destroy_node()
rclpy.shutdown()
pkg_simulation = get_package_share_directory(package_name)
robot_description_path = os.path.join(
pkg_simulation,
"urdf",
"simpleMotor.urdf",
robot_description = {"robot_description"}
if __name__ == '__main__':
main()
What am I doing wrong, and how can I fix this so that I can use ros2 nodes to simulate things in Gazebo? Would a .xml launch file be better?
