"I've already installed the necessary packages for the robot operation and completed the setup in the launch file. However, whenever I run the launch file, the joystick doesn't seem to work, and the controller isn't functioning, causing the robot model not to operate. How can I resolve this? so I use ROS2 humble
Referencing this URL: https://www.youtube.com/watchv=4QKsDf1c4hc&list=PLunhqkrRNRhYAffV8JDiFOatQXuU-NnxT&index=12
When I execute 'ros2 launch articubot_one launch_sim.launch.py world:=src/articubot_one/worlds//obstacles.world', the following events occur."
[INFO] [launch]: All log files can be found below /home/hoonle/.ros/log/2023-12-18-22-28-59-263908-hoonle135-12482 [INFO] [launch]: Default logging verbosity is set to INFO [INFO] [robot_state_publisher-1]: process started with pid [12484] [INFO] [joy_node-2]: process started with pid [12486] [INFO] [teleop_node-3]: process started with pid [12488] [INFO] [twist_mux-4]: process started with pid [12490] [INFO] [gzserver-5]: process started with pid [12492] [INFO] [gzclient-6]: process started with pid [12495] [INFO] [spawn_entity.py-7]: process started with pid [12498] [INFO] [spawner-8]: process started with pid [12506] [INFO] [spawner-9]: process started with pid [12512] [teleop_node-3] [INFO] [1702906145.170786454] [TeleopTwistJoy]: Teleop enable button 6. [teleop_node-3] [INFO] [1702906145.183447953] [TeleopTwistJoy]: Turbo on button 7. [teleop_node-3] [INFO] [1702906145.183529894] [TeleopTwistJoy]: Linear axis x on 1 at scale 0.500000. [teleop_node-3] [INFO] [1702906145.183708446] [TeleopTwistJoy]: Turbo for linear axis x is scale 1.000000. [teleop_node-3] [INFO] [1702906145.183757644] [TeleopTwistJoy]: Angular axis yaw on 0 at scale 0.500000. [teleop_node-3] [INFO] [1702906145.183791701] [TeleopTwistJoy]: Turbo for angular axis yaw is scale 1.000000. [robot_state_publisher-1] [INFO] [1702906145.884653768] [robot_state_publisher]: got segment base_footprint [robot_state_publisher-1] [INFO] [1702906145.885164739] [robot_state_publisher]: got segment base_link [robot_state_publisher-1] [INFO] [1702906145.885215727] [robot_state_publisher]: got segment camera_link [robot_state_publisher-1] [INFO] [1702906145.885238465] [robot_state_publisher]: got segment camera_link_optical [robot_state_publisher-1] [INFO] [1702906145.885260016] [robot_state_publisher]: got segment caster_wheel [robot_state_publisher-1] [INFO] [1702906145.885280587] [robot_state_publisher]: got segment chassis [robot_state_publisher-1] [INFO] [1702906145.885301213] [robot_state_publisher]: got segment face_link [robot_state_publisher-1] [INFO] [1702906145.885320870] [robot_state_publisher]: got segment laser_frame [robot_state_publisher-1] [INFO] [1702906145.885340244] [robot_state_publisher]: got segment left_wheel [robot_state_publisher-1] [INFO] [1702906145.885359744] [robot_state_publisher]: got segment right_wheel [twist_mux-4] [INFO] [1702906145.985599794] [twist_mux]: Topic handler 'topics.joystick' subscribed to topic 'cmd_vel_joy': timeout = 0.500000s , priority = 100. [twist_mux-4] [INFO] [1702906146.031988853] [twist_mux]: Topic handler 'topics.navigation' subscribed to topic 'cmd_vel': timeout = 0.500000s , priority = 10. [twist_mux-4] [INFO] [1702906146.057723243] [twist_mux]: Topic handler 'topics.tracker' subscribed to topic 'cmd_vel_tracker': timeout = 0.500000s , priority = 20. [joy_node-2] [INFO] [1702906148.870057931] [joy_node]: Opened joystick: Xbox 360 Controller. deadzone: 0.050000 [spawner-8] [INFO] [1702906151.209195415] [spawner_diff_cont]: Waiting for '/controller_manager' node to exist [spawner-9] [INFO] [1702906152.262984379] [spawner_joint_broad]: Waiting for '/controller_manager' node to exist [spawn_entity.py-7] [INFO] [1702906152.431985994] [spawn_entity]: Spawn Entity started [spawn_entity.py-7] [INFO] [1702906152.435572264] [spawn_entity]: Loading entity published on topic robot_description [spawn_entity.py-7] /opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/qos.py:307: UserWarning: DurabilityPolicy.RMW_QOS_POLICY_DURABILITY_TRANSIENT_LOCAL is deprecated. Use DurabilityPolicy.TRANSIENT_LOCAL instead. [spawn_entity.py-7] warnings.warn( [spawn_entity.py-7] [INFO] [1702906152.462296407] [spawn_entity]: Waiting for entity xml on robot_description [spawn_entity.py-7] [INFO] [1702906152.483177278] [spawn_entity]: Waiting for service /spawn_entity, timeout = 30 [spawn_entity.py-7] [INFO] [1702906152.488030881] [spawn_entity]: Waiting for service /spawn_entity [spawner-8] [INFO] [1702906153.253201370] [spawner_diff_cont]: Waiting for '/controller_manager' node to exist [spawner-9] [INFO] [1702906154.329643129] [spawner_joint_broad]: Waiting for '/controller_manager' node to exist [spawner-8] [INFO] [1702906155.333745837] [spawner_diff_cont]: Waiting for '/controller_manager' node to exist [spawn_entity.py-7] [INFO] [1702906156.038646357] [spawn_entity]: Calling service /spawn_entity [spawner-9] [INFO] [1702906156.505024238] [spawner_joint_broad]: Waiting for '/controller_manager' node to exist [spawner-8] [INFO] [1702906157.374522076] [spawner_diff_cont]: Waiting for '/controller_manager' node to exist [gzserver-5] [INFO] [1702906158.511504720] [camera_controller]: Publishing camera info to [/camera/camera_info] [spawner-9] [INFO] [1702906158.552936132] [spawner_joint_broad]: Waiting for '/controller_manager' node to exist [gzserver-5] [WARN] [1702906158.714900027] [rcl]: Found remap rule '~/out:=scan'. This syntax is deprecated. Use '--ros-args --remap ~/out:=scan' instead. [spawn_entity.py-7] [INFO] [1702906158.786377944] [spawn_entity]: Spawn status: SpawnEntity: Successfully spawned entity [my_bot] [spawner-8] [ERROR] [1702906158.918843418] [spawner_diff_cont]: Controller manager not available [gzserver-5] [WARN] [1702906159.092505281] [rcl]: Found remap rule '~/out:=scan'. This syntax is deprecated. Use '--ros-args --remap ~/out:=scan' instead. [gzserver-5] [INFO] [1702906159.631869569] [gazebo_ros2_control]: Loading gazebo_ros2_control plugin [spawner-9] [ERROR] [1702906159.804731038] [spawner_joint_broad]: Controller manager not available [INFO] [spawn_entity.py-7]: process has finished cleanly [pid 12498] [gzserver-5] [INFO] [1702906160.131269697] [gazebo_ros2_control]: Starting gazebo_ros2_control plugin in namespace: / [gzserver-5] [INFO] [1702906160.134292559] [gazebo_ros2_control]: Starting gazebo_ros2_control plugin in ros 2 node: gazebo_ros2_control [gzserver-5] [INFO] [1702906160.137459190] [gazebo_ros2_control]: Loading parameter files /home/hoonle/dev_ws/install/articubot_one/share/articubot_one/config/my_controllers.yaml [gzserver-5] [INFO] [1702906160.142078293] [gazebo_ros2_control]: Loading parameter files /home/hoonle/dev_ws/install/articubot_one/share/articubot_one/config/gaz_ros2_ctl_use_sim.yaml [gzserver-5] [INFO] [1702906160.407563766] [gazebo_ros2_control]: connected to service!! robot_state_publisher [gzserver-5] [INFO] [1702906160.413188506] [gazebo_ros2_control]: Received urdf from param server, parsing... [ERROR] [spawner-8]: process has died [pid 12506, exit code 1, cmd '/opt/ros/humble/lib/controller_manager/spawner diff_cont --ros-args']. [gzserver-5] [INFO] [1702906160.616743943] [gazebo_ros2_control]: Loading joint: left_wheel_joint [gzserver-5] [INFO] [1702906160.617521531] [gazebo_ros2_control]: State: [gzserver-5] [INFO] [1702906160.617592564] [gazebo_ros2_control]: velocity [gzserver-5] [INFO] [1702906160.617631934] [gazebo_ros2_control]: position [gzserver-5] [INFO] [1702906160.617663410] [gazebo_ros2_control]: Command: [gzserver-5] [INFO] [1702906160.617726429] [gazebo_ros2_control]: velocity [gzserver-5] [INFO] [1702906160.617767571] [gazebo_ros2_control]: Loading joint: right_wheel_joint [gzserver-5] [INFO] [1702906160.617797019] [gazebo_ros2_control]: State: [gzserver-5] [INFO] [1702906160.617822631] [gazebo_ros2_control]: velocity [gzserver-5] [INFO] [1702906160.617848121] [gazebo_ros2_control]: position [gzserver-5] [INFO] [1702906160.617872919] [gazebo_ros2_control]: Command: [gzserver-5] [INFO] [1702906160.619132016] [gazebo_ros2_control]: velocity [gzserver-5] [INFO] [1702906160.619361862] [resource_manager]: Initialize hardware 'GazeboSystem' [gzserver-5] [INFO] [1702906160.621804402] [resource_manager]: Successful initialization of hardware 'GazeboSystem' [gzserver-5] [INFO] [1702906160.622799508] [resource_manager]: 'configure' hardware 'GazeboSystem' [gzserver-5] [INFO] [1702906160.622846051] [resource_manager]: Successful 'configure' of hardware 'GazeboSystem' [gzserver-5] [INFO] [1702906160.622867518] [resource_manager]: 'activate' hardware 'GazeboSystem' [gzserver-5] [INFO] [1702906160.622886590] [resource_manager]: Successful 'activate' of hardware 'GazeboSystem' [gzserver-5] [INFO] [1702906160.625476274] [gazebo_ros2_control]: Loading controller_manager [gzserver-5] [INFO] [1702906160.913622535] [controller_manager]: Subscribing to '~/robot_description' topic for robot description file. [ERROR] [spawner-9]: process has died [pid 12512, exit code 1, cmd '/opt/ros/humble/lib/controller_manager/spawner joint_broad --ros-args']. [gzserver-5] [WARN] [1702906161.118151328] [gazebo_ros2_control]: Desired controller update period (0.0333333 s) is slower than the gazebo simulation period (0.001 s). [gzserver-5] [INFO] [1702906161.121703280] [gazebo_ros2_control]: Loaded gazebo_ros2_control. [gzclient-6] context mismatch in svga_surface_destroy [gzclient-6] context mismatch in svga_surface_destroy
and my controllers yamlfile
controller_manager: ros__parameters: update_rate: 30 # use_sim_time: true
diff_cont:
type: diff_drive_controller/DiffDriveController
joint_broad:
type: joint_state_broadcaster/JointStateBroadcaster
diff_cont: ros__parameters:
publish_rate: 50.0
base_frame_id: base_link
left_wheel_names: ['left_wheel_joint']
right_wheel_names: ['right_wheel_joint']
wheel_separation: 0.297
wheel_radius: 0.033
use_stamped_vel: false
# open_loop: false
# wheels_per_side: x
# wheel_separation_multiplier: x
# left_wheel_radius_multiplier: x
# right_wheel_radius_multiplier: x
# odom_frame_id: x
# pose_covariance_diagonal: x
# twist_covariance_diagonal: x
# open_loop: x
# enable_odom_tf: x
# cmd_vel_timeout: x
# publish_limited_velocity: x
# velocity_rolling_window_size: x
# linear.x.has_velocity_limits: false
# linear.x.has_acceleration_limits: false
# linear.x.has_jerk_limits: false
# linear.x.max_velocity: NAN
# linear.x.min_velocity: NAN
# linear.x.max_acceleration: NAN
# linear.x.min_acceleration: NAN
# linear.x.max_jerk: NAN
# linear.x.min_jerk: NAN
# angular.z.has_velocity_limits: false
# angular.z.has_acceleration_limits: false
# angular.z.has_jerk_limits: false
# angular.z.max_velocity: NAN
# angular.z.min_velocity: NAN
# angular.z.max_acceleration: NAN
# angular.z.min_acceleration: NAN
# angular.z.max_jerk: NAN
# angular.z.min_jerk: NAN
# joint_broad:
# ros__parameters:
finaly my launch file
import os
from ament_index_python.packages import get_package_share_directory
from launch import LaunchDescription from launch.actions import IncludeLaunchDescription from launch.launch_description_sources import PythonLaunchDescriptionSource
from launch_ros.actions import Node
# Include the robot_state_publisher launch file, provided by our own package. Force sim time to be enabled
# !!! MAKE SURE YOU SET THE PACKAGE NAME CORRECTLY !!!
package_name='articubot_one' #<--- CHANGE ME
rsp = IncludeLaunchDescription(
PythonLaunchDescriptionSource([os.path.join(
get_package_share_directory(package_name),'launch','rsp.launch.py'
)]), launch_arguments={'use_sim_time': 'true', 'use_ros2_control': 'true'}.items()
joystick = IncludeLaunchDescription(
get_package_share_directory(package_name),'launch','joystick.launch.py'
)]), launch_arguments={'use_sim_time': 'true'}.items()
twist_mux_params = os.path.join(get_package_share_directory(package_name),'config','twist_mux.yaml')
twist_mux = Node(
package="twist_mux",
executable="twist_mux",
parameters=[twist_mux_params, {'use_sim_time': True}],
remappings=[('/cmd_vel_out','/diff_cont/cmd_vel_unstamped')]
gazebo_params_file = os.path.join(get_package_share_directory(package_name),'config','gazebo_params.yaml')
# Include the Gazebo launch file, provided by the gazebo_ros package
gazebo = IncludeLaunchDescription(
get_package_share_directory('gazebo_ros'), 'launch', 'gazebo.launch.py')]),
launch_arguments={'extra_gazebo_args': '--ros-args --params-file ' + gazebo_params_file}.items()
# Run the spawner node from the gazebo_ros package. The entity name doesn't really matter if you only have a single robot.
spawn_entity = Node(package='gazebo_ros', executable='spawn_entity.py',
arguments=['-topic', 'robot_description',
'-entity', 'my_bot'],
output='screen')
diff_drive_spawner = Node(
package="controller_manager",
executable="spawner",
arguments=["diff_cont"],
joint_broad_spawner = Node(
arguments=["joint_broad"],
# Code for delaying a node (I haven't tested how effective it is)
# First add the below lines to imports
# from launch.actions import RegisterEventHandler
# from launch.event_handlers import OnProcessExit
# Then add the following below the current diff_drive_spawner
# delayed_diff_drive_spawner = RegisterEventHandler(
# event_handler=OnProcessExit(
# target_action=spawn_entity,
# on_exit=[diff_drive_spawner],
# Replace the diff_drive_spawner in the final return with delayed_diff_drive_spawner
# Launch them all!
return LaunchDescription([
rsp,
joystick,
twist_mux,
gazebo,
spawn_entity,
diff_drive_spawner,
joint_broad_spawner
this is my list hardware interfaces
hoonle@hoonle135:~/dev_ws$ ros2 control list_hardware_interfaces
command interfaces
left_wheel_joint/velocity [available] [unclaimed]
right_wheel_joint/velocity [available] [unclaimed]
state interfaces
left_wheel_joint/position
right_wheel_joint/position
hoonle@hoonle135:~/dev_ws$ ros2 run controller_manager spawner.py diff_cont
No executable found
I would really appreciate your assistance. Could you please help me?
