I'm simulating a robot with 4 omnidirectional wheels and I'm using the planar move plugin in the gazebo to simulate the behavior of the omnidirectional wheels.
To simulate the wheels I was using continuous joints however with this plugin in rviz2 and with the fixed frame in odom, the wheels do not move with the robot. Although if I'm using a fixed joint and controlling the robot with teleop_twist_keyboard the wheels move together with the robot.
Is this a plugin problem or am I missing something to declare?
Follows URDF code to create the robot.
robot_core:
<?xml version="1.0"?>
<robot xmlns:xacro="http://www.ros.org/wiki/xacro" >
<xacro:include filename="inertial_macros.xacro"/>
<xacro:include filename="gazebo_control.xacro" />
<material name="white">
<color rgba="1 1 1 1"/>
</material>
<material name="blue">
<color rgba="0.2 0.2 1 1"/>
</material>
<material name="black">
<color rgba="0 0 0 1"/>
</material>
<material name="red">
<color rgba="1 0 0 1"/>
</material>
<!--BASE LINK-->
<link name="base_link">
</link>
<!--CHASSI-->
<joint name="chassi_joint" type="fixed">
<parent link="base_link"/>
<child link="chassi_link"/>
<origin xyz="0 0 0"/> <!--VIRADO PARA X-->
<!--<origin xyz="0 0 0" rpy="0 0 ${pi/2}"/> VIRADO PARA Y-->
</joint>
<link name="chassi_link">
<visual>
<origin xyz="0 0 0.085"/>
<geometry>
<cylinder radius="0.275" length="0.17"/>
</geometry>
<material name="white"/>
</visual>
<collision>
<geometry>
</geometry>
</collision>
<xacro:inertial_cylinder mass="0.1" length="0.17" radius="0.275">
<origin xyz="0 0 0.085" rpy="0 0 0"/>
</xacro:inertial_cylinder>
</link>
<gazebo reference="chassi_link">
<material>Gazebo/White</material>
</gazebo>
<!--BODY-->
<joint name="body_joint" type="fixed">
<parent link="chassi_link"/>
<child link="body_link"/>
<origin xyz="-0.1 0 0.18" rpy="0 0 0"/>
</joint>
<link name="body_link">
<visual>
<origin xyz="0 0 0.55" rpy="0 0 ${pi/2}"/>
<geometry>
<box size="0.2 0.05 1.1"/>
</geometry>
</visual>
<collision>
<geometry>
</geometry>
</collision>
<xacro:inertial_box mass="0.1" x="0.2" y="0.05" z="1.1">
<origin xyz="0 0 0.55" rpy="0 0 0"/>
</xacro:inertial_box>
</link>
<gazebo reference="body_link">
</gazebo>
<!--WHEELS-->
<!--LEFT FRONT-->
<joint name="left_front_joint" type="fixed">
<child link="left_front_link"/>
<origin xyz="0.2 0.2 0" rpy="-${pi/2} 0 -${pi/4}"/>
<!--<axis xyz="0 0 1"/>-->
</joint>
<link name="left_front_link">
<visual>
<geometry>
<cylinder radius="0.1" length="0.04"/>
</geometry>
<material name="blue"/>
</visual>
<collision>
<geometry>
</geometry>
</collision>
<xacro:inertial_cylinder mass="0.1" length="0.04" radius="0.1">
<origin xyz="0 0 0" rpy="0 0 0"/>
</link>
<gazebo reference="left_front_link">
<material>Gazebo/Blue</material>
<mu1 value="0.001"/>
<mu2 value="0.001"/>
</gazebo>
<!--LEFT BACK-->
<joint name="left_back_joint" type="fixed">
<child link="left_back_link"/>
<origin xyz="-0.2 0.2 0" rpy="0 -${pi/2} -${pi/4}"/>
</joint>
<link name="left_back_link">
<visual>
<geometry>
</geometry>
<material name="black"/>
</visual>
<collision>
<geometry>
</geometry>
</collision>
</link>
<gazebo reference="left_back_link">
<material>Gazebo/Black</material>
</gazebo>
<!--RIGHT FRONT-->
<joint name="right_front_joint" type="fixed">
<child link="right_front_link"/>
<origin xyz="0.2 -0.2 0" rpy="0 ${pi/2} -${pi/4}"/>
<!--<axis xyz="0 0 -1"/>-->
</joint>
<link name="right_front_link">
<visual>
<geometry>
</geometry>
</visual>
<collision>
<geometry>
</geometry>
</collision>
</link>
<gazebo reference="right_front_link">
</gazebo>
<!--RIGHT BACK-->
<joint name="right_back_joint" type="fixed">
<child link="right_back_link"/>
<origin xyz="-0.2 -0.2 0" rpy="${pi/2} 0 -${pi/4}"/>
</joint>
<link name="right_back_link">
<visual>
<geometry>
</geometry>
</visual>
<collision>
<geometry>
</geometry>
</collision>
</link>
<gazebo reference="right_back_link">
</gazebo>
<xacro:omni_steering/>
</robot>
gazebo_control:
<robot xmlns:xacro="http://www.ros.org/wiki/xacro">
<xacro:macro name="omni_steering" params="">
<gazebo>
<plugin name="omni_steering" filename="libgazebo_ros_planar_move.so">
<commandTopic>cmd_vel</commandTopic>
<odometry_rate>50.0</odometry_rate>
<odometry_frame>odom</odometry_frame>
<robot_base_frame>base_link</robot_base_frame>
<publish_odom>true</publish_odom>
<publish_odom_tf>true</publish_odom_tf>
<publish_wheel_tf>true</publish_wheel_tf>
</plugin>
</gazebo>
</xacro:macro>
</robot>
robot_xacro:
<robot xmlns:xacro="http://www.ros.org/wiki/xacro" name="robot">
<xacro:include filename="robot_core.xacro" />
</robot>
rsp.launch.py:
import os
from ament_index_python.packages import get_package_share_directory
from launch import LaunchDescription from launch.substitutions import LaunchConfiguration from launch.actions import DeclareLaunchArgument from launch_ros.actions import Node
import xacro
# Check if we're told to use sim time
use_sim_time = LaunchConfiguration('use_sim_time')
# Process the URDF file
pkg_path = os.path.join(get_package_share_directory('charmie_bot'))
xacro_file = os.path.join(pkg_path,'description','robot.urdf.xacro')
robot_description_config = xacro.process_file(xacro_file)
# Create a robot_state_publisher node
params = {'robot_description': robot_description_config.toxml(), 'use_sim_time': use_sim_time}
node_robot_state_publisher = Node(
package='robot_state_publisher',
executable='robot_state_publisher',
output='screen',
parameters=[params]
# Launch!
return LaunchDescription([
DeclareLaunchArgument(
'use_sim_time',
default_value='false',
description='Use sim time if true'),
launch_sim.launch.py:
import os
from launch import LaunchDescription from launch.actions import IncludeLaunchDescription from launch.launch_description_sources import PythonLaunchDescriptionSource
package_name='charmie_bot' #<--- CHANGE ME
rsp = IncludeLaunchDescription(
PythonLaunchDescriptionSource([os.path.join(
get_package_share_directory(package_name),'launch','rsp.launch.py'
)]), launch_arguments={'use_sim_time': 'true'}.items()
# Include the Gazebo launch file, provided by the gazebo_ros package
gazebo = IncludeLaunchDescription(
get_package_share_directory('gazebo_ros'), 'launch', 'gazebo.launch.py')]),
# Run the spawner node from the gazebo_ros package. The entity name doesn't really matter if you only have a single robot.
spawn_entity = Node(package='gazebo_ros', executable='spawn_entity.py',
arguments=['-topic', 'robot_description',
'-entity', 'my_bot'],
output='screen')
# Launch them all!
rsp,
gazebo,
spawn_entity
