I am trying to run the MoveIt Quickstart in RViz tutorial. Unfortunately, RViz crashes during the launch. My problem seems similar to this one but that is built on a windows system, so it seems a bit different.
My environment
ROS Distro: Humble
OS Version: Ubuntu 22.04
Source build: Main
System: Laptop: Razor Blade
Memory: Intel® Core™ i7-8750H CPU @ 2.20GHz × 12
Graphics: NV136 / Mesa Intel® UHD Graphics 630 (CFL GT2)
Disk: 1 TB
I have fairly clean build of Ubuntu 22.04. That said, building Moveit2 was giving me a hard time. I only built successfully with: MAKEFLAGS="-j4 -l1" colcon build --executor sequential RViz is built using the source files in the /opt/ros/humble directory (I think that is the default install location while following the Ros2 setup tutorial). The rviz_visual_tools package is built from home/jake/ws_moveit/src and is located in home/jake/ws_moveit/build.
Backtrace
ws_moveit$ ros2 launch moveit2_tutorials demo.launch.py
[INFO] [launch]: All log files can be found below /home/jake/.ros/log/2024-03-13-11-07-50-050628-jake-Blade-29447
[INFO] [launch]: Default logging verbosity is set to INFO
[INFO] [rviz2-1]: process started with pid [29448]
[INFO] [static_transform_publisher-2]: process started with pid [29450]
[INFO] [robot_state_publisher-3]: process started with pid [29452]
[INFO] [move_group-4]: process started with pid [29454]
[INFO] [ros2_control_node-5]: process started with pid [29456]
[INFO] [spawner-6]: process started with pid [29458]
[INFO] [spawner-7]: process started with pid [29460]
[INFO] [spawner-8]: process started with pid [29462]
[rviz2-1] Warning: Ignoring XDG_SESSION_TYPE=wayland on Gnome. Use QT_QPA_PLATFORM=wayland to run on Wayland anyway.
[static_transform_publisher-2] [INFO] [1710353270.599045049] [static_transform_publisher]: Spinning until stopped - publishing transform
[static_transform_publisher-2] translation: ('0.000000', '0.000000', '0.000000')
[static_transform_publisher-2] rotation: ('0.000000', '0.000000', '0.000000', '1.000000')
[static_transform_publisher-2] from 'world' to 'base_link'
[robot_state_publisher-3] [INFO] [1710353270.626137892] [robot_state_publisher]: got segment base_link
[robot_state_publisher-3] [INFO] [1710353270.626282510] [robot_state_publisher]: got segment bracelet_link
[robot_state_publisher-3] [INFO] [1710353270.626302550] [robot_state_publisher]: got segment end_effector_link
[robot_state_publisher-3] [INFO] [1710353270.626314832] [robot_state_publisher]: got segment forearm_link
[robot_state_publisher-3] [INFO] [1710353270.626325727] [robot_state_publisher]: got segment half_arm_1_link
[robot_state_publisher-3] [INFO] [1710353270.626336031] [robot_state_publisher]: got segment half_arm_2_link
[robot_state_publisher-3] [INFO] [1710353270.626346514] [robot_state_publisher]: got segment robotiq_85_base_link
[robot_state_publisher-3] [INFO] [1710353270.626357257] [robot_state_publisher]: got segment robotiq_85_left_finger_link
[robot_state_publisher-3] [INFO] [1710353270.626367777] [robot_state_publisher]: got segment robotiq_85_left_finger_tip_link
[robot_state_publisher-3] [INFO] [1710353270.626378339] [robot_state_publisher]: got segment robotiq_85_left_inner_knuckle_link
[robot_state_publisher-3] [INFO] [1710353270.626388758] [robot_state_publisher]: got segment robotiq_85_left_knuckle_link
[robot_state_publisher-3] [INFO] [1710353270.626398671] [robot_state_publisher]: got segment robotiq_85_right_finger_link
[robot_state_publisher-3] [INFO] [1710353270.626408600] [robot_state_publisher]: got segment robotiq_85_right_finger_tip_link
[robot_state_publisher-3] [INFO] [1710353270.626418496] [robot_state_publisher]: got segment robotiq_85_right_inner_knuckle_link
[robot_state_publisher-3] [INFO] [1710353270.626443678] [robot_state_publisher]: got segment robotiq_85_right_knuckle_link
[robot_state_publisher-3] [INFO] [1710353270.626450662] [robot_state_publisher]: got segment shoulder_link
[robot_state_publisher-3] [INFO] [1710353270.626458236] [robot_state_publisher]: got segment spherical_wrist_1_link
[robot_state_publisher-3] [INFO] [1710353270.626465807] [robot_state_publisher]: got segment spherical_wrist_2_link
[robot_state_publisher-3] [INFO] [1710353270.626474813] [robot_state_publisher]: got segment world
[ros2_control_node-5] [INFO] [1710353270.638806992] [controller_manager]: Subscribing to '~/robot_description' topic for robot description file.
[ros2_control_node-5] [INFO] [1710353270.640367296] [controller_manager]: update rate is 1000 Hz
[ros2_control_node-5] [INFO] [1710353270.640584825] [controller_manager]: RT kernel is recommended for better performance
[ros2_control_node-5] [INFO] [1710353270.650818834] [controller_manager]: Received robot description file.
[ros2_control_node-5] [INFO] [1710353270.651640178] [resource_manager]: Loading hardware 'KortexMultiInterfaceHardware'
[ros2_control_node-5] [INFO] [1710353270.652670593] [resource_manager]: Initialize hardware 'KortexMultiInterfaceHardware'
[ros2_control_node-5] [WARN] [1710353270.652699997] [mock_generic_system]: Parameter 'fake_sensor_commands' has been deprecated from usage. Use'mock_sensor_commands' instead.
[ros2_control_node-5] [WARN] [1710353270.652734799] [mock_generic_system]: Parsing of optional initial interface values failed or uses a deprecated format. Add initial values for every state interface in the ros2_control.xacro. For example:
[ros2_control_node-5] <state_interface name="velocity">
[ros2_control_node-5] 0.0
[ros2_control_node-5] </state_interface>
[ros2_control_node-5] [INFO] [1710353270.652751403] [resource_manager]: Successful initialization of hardware 'KortexMultiInterfaceHardware'
[ros2_control_node-5] [INFO] [1710353270.652780335] [resource_manager]: Loading hardware 'RobotiqGripperHardwareInterface'
[ros2_control_node-5] [INFO] [1710353270.652798744] [resource_manager]: Initialize hardware 'RobotiqGripperHardwareInterface'
[ros2_control_node-5] [WARN] [1710353270.652813936] [mock_generic_system]: Parameter 'fake_sensor_commands' has been deprecated from usage. Use'mock_sensor_commands' instead.
[ros2_control_node-5] [INFO] [1710353270.652836302] [resource_manager]: Successful initialization of hardware 'RobotiqGripperHardwareInterface'
[ros2_control_node-5] [INFO] [1710353270.652904956] [resource_manager]: 'configure' hardware 'RobotiqGripperHardwareInterface'
[ros2_control_node-5] [INFO] [1710353270.652926715] [resource_manager]: Successful 'configure' of hardware 'RobotiqGripperHardwareInterface'
[ros2_control_node-5] [INFO] [1710353270.652938272] [resource_manager]: 'activate' hardware 'RobotiqGripperHardwareInterface'
[ros2_control_node-5] [INFO] [1710353270.652945529] [resource_manager]: Successful 'activate' of hardware 'RobotiqGripperHardwareInterface'
[ros2_control_node-5] [INFO] [1710353270.652953124] [resource_manager]: 'configure' hardware 'KortexMultiInterfaceHardware'
[ros2_control_node-5] [INFO] [1710353270.652963177] [resource_manager]: Successful 'configure' of hardware 'KortexMultiInterfaceHardware'
[ros2_control_node-5] [INFO] [1710353270.652974837] [resource_manager]: 'activate' hardware 'KortexMultiInterfaceHardware'
[ros2_control_node-5] [INFO] [1710353270.652981752] [resource_manager]: Successful 'activate' of hardware 'KortexMultiInterfaceHardware'
[move_group-4] [INFO] [1710353270.672341286] [move_group.moveit.RDFLoader]: Loaded robot model in 0.0052989 seconds
[move_group-4] [INFO] [1710353270.672404928] [move_group.moveit.robot_model]: Loading robot model 'gen3'...
[move_group-4] [INFO] [1710353270.672421428] [move_group.moveit.robot_model]: No root/virtual joint specified in SRDF. Assuming fixed joint
[ros2_control_node-5] [INFO] [1710353270.783256464] [controller_manager]: Received robot description file.
[ros2_control_node-5] [WARN] [1710353270.783301276] [controller_manager]: ResourceManager has already loaded an urdf file. Ignoring attempt to reload a robot description file.
[move_group-4] [INFO] [1710353270.832842673] [move_group.moveit.kdl_kinematics_plugin]: Joint weights for group 'manipulator': 1 1 1 1 1 1 1
[move_group-4] malloc(): invalid size (unsorted)
[ros2_control_node-5] [INFO] [1710353270.944747493] [controller_manager]: Loading controller 'joint_state_broadcaster'
[ros2_control_node-5] [INFO] [1710353270.957491361] [controller_manager]: Loading controller 'joint_trajectory_controller'
[ros2_control_node-5] [WARN] [1710353270.970609689] [joint_trajectory_controller]: [Deprecated]: "allow_nonzero_velocity_at_trajectory_end" is set to true. The default behavior will change to false.
[ros2_control_node-5] [INFO] [1710353270.974082403] [controller_manager]: Loading controller 'robotiq_gripper_controller'
[rviz2-1] [INFO] [1710353270.990812563] [rviz2]: Stereo is NOT SUPPORTED
[rviz2-1] [INFO] [1710353270.990990897] [rviz2]: OpenGl version: 4.6 (GLSL 4.6)
[spawner-6] [INFO] [1710353270.991016624] [spawner_joint_state_broadcaster]: Loaded joint_state_broadcaster
[ros2_control_node-5] [INFO] [1710353270.992116534] [controller_manager]: Configuring controller 'joint_state_broadcaster'
[ros2_control_node-5] [INFO] [1710353270.992237918] [joint_state_broadcaster]: 'joints' or 'interfaces' parameter is empty. All available state interfaces will be published
[spawner-7] [INFO] [1710353271.002768400] [spawner_joint_trajectory_controller]: Loaded joint_trajectory_controller
[spawner-6] [INFO] [1710353271.002828010] [spawner_joint_state_broadcaster]: Configured and activated joint_state_broadcaster
[ros2_control_node-5] [INFO] [1710353271.004004066] [controller_manager]: Configuring controller 'joint_trajectory_controller'
[ros2_control_node-5] [INFO] [1710353271.004223576] [joint_trajectory_controller]: No specific joint names are used for command interfaces. Using 'joints' parameter.
[ros2_control_node-5] [INFO] [1710353271.004273761] [joint_trajectory_controller]: Command interfaces are [position] and state interfaces are [position velocity].
[ros2_control_node-5] [INFO] [1710353271.004295607] [joint_trajectory_controller]: Using 'splines' interpolation method.
[ros2_control_node-5] [INFO] [1710353271.005583050] [joint_trajectory_controller]: Controller state will be published at 100.00 Hz.
[ros2_control_node-5] [INFO] [1710353271.007092888] [joint_trajectory_controller]: Action status changes will be monitored at 20.00 Hz.
[spawner-8] [INFO] [1710353271.011478647] [spawner_robotiq_gripper_controller]: Loaded robotiq_gripper_controller
[ros2_control_node-5] [INFO] [1710353271.013969993] [controller_manager]: Configuring controller 'robotiq_gripper_controller'
[ros2_control_node-5] [INFO] [1710353271.014043030] [robotiq_gripper_controller]: Action status changes will be monitored at 20Hz.
[rviz2-1] [INFO] [1710353271.015404363] [rviz2]: Stereo is NOT SUPPORTED
[spawner-7] [INFO] [1710353271.017632911] [spawner_joint_trajectory_controller]: Configured and activated joint_trajectory_controller
[spawner-8] [INFO] [1710353271.023057065] [spawner_robotiq_gripper_controller]: Configured and activated robotiq_gripper_controller
[rviz2-1] [WARN] [1710353271.139714520] [rcl.logging_rosout]: Publisher already registered for provided node name. If this is due to multiple nodes with the same name then all logs for that logger name will go out over the existing publisher. As soon as any node with that name is destructed it will unregister the publisher, preventing any further logs for that name from being published on the rosout topic.
[INFO] [spawner-6]: process has finished cleanly [pid 29458]
[rviz2-1] Warning: class_loader.impl: SEVERE WARNING!!! A namespace collision has occurred with plugin factory for class rviz_default_plugins::displays::InteractiveMarkerDisplay. New factory will OVERWRITE existing one. This situation occurs when libraries containing plugins are directly linked against an executable (the one running right now generating this message). Please separate plugins out into their own library or just don't link against the library and use either class_loader::ClassLoader/MultiLibraryClassLoader to open.
[rviz2-1] at line 253 in /opt/ros/humble/include/class_loader/class_loader/class_loader_core.hpp
[INFO] [spawner-7]: process has finished cleanly [pid 29460]
[INFO] [spawner-8]: process has finished cleanly [pid 29462]
[rviz2-1] [INFO] [1710353271.176152493] [rviz2.RDFLoader]: Loaded robot model in 0.00404517 seconds
[rviz2-1] [INFO] [1710353271.176198601] [rviz2.robot_model]: Loading robot model 'gen3'...
[rviz2-1] [INFO] [1710353271.176211876] [rviz2.robot_model]: No root/virtual joint specified in SRDF. Assuming fixed joint
[rviz2-1] [ERROR] [1710353274.479695119] [rviz2.motion_planning_frame]: Action server: /recognize_objects not available
[rviz2-1] [INFO] [1710353274.512168557] [rviz2.motion_planning_frame]: MoveGroup namespace changed: / -> . Reloading params.
[rviz2-1] [INFO] [1710353274.569129278] [rviz2.RDFLoader]: Loaded robot model in 0.00339469 seconds
[rviz2-1] [INFO] [1710353274.569187604] [rviz2.robot_model]: Loading robot model 'gen3'...
[rviz2-1] [INFO] [1710353274.569195104] [rviz2.robot_model]: No root/virtual joint specified in SRDF. Assuming fixed joint
[rviz2-1] [INFO] [1710353274.688392692] [rviz2.kdl_kinematics_plugin]: Joint weights for group 'manipulator': 1 1 1 1 1 1 1
[rviz2-1] malloc(): invalid size (unsorted)
[ERROR] [rviz2-1]: process has died [pid 29448, exit code -6, cmd '/opt/ros/humble/lib/rviz2/rviz2 -d /home/jake/ws_moveit/install/moveit2_tutorials/share/moveit2_tutorials/launch/kinova_moveit_config_demo.rviz --ros-args -r __node:=rviz2 --params-file /tmp/launch_params_3gp4h4ru --params-file /tmp/launch_params_yf08k9sp --params-file /tmp/launch_params_rexkmkx2 --params-file /tmp/launch_params_gvv5k1nd --params-file /tmp/launch_params_50z88v97'].
[re-opening rviz in another terminal by copying the failed command]
~$ /opt/ros/humble/lib/rviz2/rviz2 -d /home/jake/ws_moveit/install/moveit2_tutorials/share/moveit2_tutorials/launch/kinova_moveit_config_demo.rviz --ros-args -r __node:=rviz2 --params-file /tmp/launch_params_zvqp4djf --params-file /tmp/launch_params_6mafmodg --params-file /tmp/launch_params_wp9kk605 --params-file /tmp/launch_params_e0rrm3pp --params-file /tmp/launch_params_ojrrr3n1
2024-03-19 15:04:33.224 [RTPS_TRANSPORT_SHM Error] Failed init_port fastrtps_port7419: open_and_lock_file failed -> Function open_port_internal
[INFO] [1710885873.440879568] [rviz2]: Stereo is NOT SUPPORTED
[INFO] [1710885873.441000848] [rviz2]: OpenGl version: 4.6 (GLSL 4.6)
[INFO] [1710885873.457910955] [rviz2]: Stereo is NOT SUPPORTED
[INFO] [1710885873.762579888] [moveit_rdf_loader.rdf_loader]: Loaded robot model in 0.00221443 seconds
[INFO] [1710885873.762623689] [moveit_robot_model.robot_model]: Loading robot model 'gen3'...
[INFO] [1710885873.762635502] [moveit_robot_model.robot_model]: No root/virtual joint specified in SRDF. Assuming fixed joint
[ERROR] [1710885877.067277905] [moveit_ros_visualization.motion_planning_frame]: Action server: /recognize_objects not available
[INFO] [1710885877.104106015] [moveit_ros_visualization.motion_planning_frame]: MoveGroup namespace changed: / -> . Reloading params.
[INFO] [1710885877.165162052] [moveit_rdf_loader.rdf_loader]: Loaded robot model in 0.00149257 seconds
[INFO] [1710885877.165219429] [moveit_robot_model.robot_model]: Loading robot model 'gen3'...
[INFO] [1710885877.165259758] [moveit_robot_model.robot_model]: No root/virtual joint specified in SRDF. Assuming fixed joint
[INFO] [1710885877.535754437] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Starting planning scene monitor
[INFO] [1710885877.536078152] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Listening to '/monitored_planning_scene'
[INFO] [1710885877.540744370] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Starting planning scene monitor
[INFO] [1710885877.541021369] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Listening to '/monitored_planning_scene'
[INFO] [1710885877.550704306] [interactive_marker_display_108082219662592]: Connected on namespace: /rviz_moveit_motion_planning_display/robot_interaction_interactive_marker_topic
[INFO] [1710885877.556399553] [moveit_ros_robot_interaction.robot_interaction]: No active joints or end effectors found for group 'gripper'. Make sure that kinematics.yaml is loaded in this node's namespace.
[INFO] [1710885877.557223212] [moveit_ros_robot_interaction.robot_interaction]: No active joints or end effectors found for group 'gripper'. Make sure that kinematics.yaml is loaded in this node's namespace.
[INFO] [1710885877.569453373] [interactive_marker_display_108082219662592]: Sending request for interactive markers
[INFO] [1710885877.599711641] [interactive_marker_display_108082219662592]: Service response received for initialization
[INFO] [1710885882.540783118] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Failed to call service get_planning_scene, have you launched move_group or called psm.providePlanningSceneService()?
[INFO] [1710885882.559926196] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Failed to call service get_planning_scene, have you launched move_group or called psm.providePlanningSceneService()?
[INFO] [1710885882.560067730] [moveit_ros_visualization.motion_planning_frame]: group gripper
[INFO] [1710885882.560102654] [moveit_ros_visualization.motion_planning_frame]: Constructing new MoveGroup connection for group 'gripper' in namespace ''
[This time RViz stay active and actually shows the robot.]
Still got the namespace warning. I tried locate interactive_markers
and got the following output:
/opt/ros/humble/include/interactive_markers
/opt/ros/humble/include/interactive_markers/interactive_markers
/opt/ros/humble/include/interactive_markers/interactive_markers/exceptions.hpp
/opt/ros/humble/include/interactive_markers/interactive_markers/interactive_marker_client.hpp
/opt/ros/humble/include/interactive_markers/interactive_markers/interactive_marker_server.hpp
/opt/ros/humble/include/interactive_markers/interactive_markers/menu_handler.hpp
/opt/ros/humble/include/interactive_markers/interactive_markers/message_context.hpp
/opt/ros/humble/include/interactive_markers/interactive_markers/tools.hpp
/opt/ros/humble/include/interactive_markers/interactive_markers/visibility_control.hpp
/opt/ros/humble/include/rviz_default_plugins/rviz_default_plugins/displays/interactive_markers
/opt/ros/humble/include/rviz_default_plugins/rviz_default_plugins/displays/interactive_markers/integer_action.hpp
/opt/ros/humble/include/rviz_default_plugins/rviz_default_plugins/displays/interactive_markers/interactive_marker.hpp
/opt/ros/humble/include/rviz_default_plugins/rviz_default_plugins/displays/interactive_markers/interactive_marker_control.hpp
/opt/ros/humble/include/rviz_default_plugins/rviz_default_plugins/displays/interactive_markers/interactive_marker_display.hpp
/opt/ros/humble/include/rviz_default_plugins/rviz_default_plugins/displays/interactive_markers/interactive_marker_namespace_property.hpp
/opt/ros/humble/include/visualization_msgs/visualization_msgs/srv/get_interactive_markers.h
/opt/ros/humble/include/visualization_msgs/visualization_msgs/srv/get_interactive_markers.hpp
/opt/ros/humble/include/visualization_msgs/visualization_msgs/srv/detail/get_interactive_markers__builder.hpp
/opt/ros/humble/include/visualization_msgs/visualization_msgs/srv/detail/get_interactive_markers__functions.c
/opt/ros/humble/include/visualization_msgs/visualization_msgs/srv/detail/get_interactive_markers__functions.h
/opt/ros/humble/include/visualization_msgs/visualization_msgs/srv/detail/get_interactive_markers__rosidl_typesupport_fastrtps_c.h
/opt/ros/humble/include/visualization_msgs/visualization_msgs/srv/detail/get_interactive_markers__rosidl_typesupport_fastrtps_cpp.hpp
/opt/ros/humble/include/visualization_msgs/visualization_msgs/srv/detail/get_interactive_markers__rosidl_typesupport_introspection_c.h
/opt/ros/humble/include/visualization_msgs/visualization_msgs/srv/detail/get_interactive_markers__rosidl_typesupport_introspection_cpp.hpp
/opt/ros/humble/include/visualization_msgs/visualization_msgs/srv/detail/get_interactive_markers__struct.h
/opt/ros/humble/include/visualization_msgs/visualization_msgs/srv/detail/get_interactive_markers__struct.hpp
/opt/ros/humble/include/visualization_msgs/visualization_msgs/srv/detail/get_interactive_markers__traits.hpp
/opt/ros/humble/include/visualization_msgs/visualization_msgs/srv/detail/get_interactive_markers__type_support.c
/opt/ros/humble/include/visualization_msgs/visualization_msgs/srv/detail/get_interactive_markers__type_support.cpp
/opt/ros/humble/include/visualization_msgs/visualization_msgs/srv/detail/get_interactive_markers__type_support.h
/opt/ros/humble/lib/libinteractive_markers.so
/opt/ros/humble/local/lib/python3.10/dist-packages/interactive_markers
/opt/ros/humble/local/lib/python3.10/dist-packages/interactive_markers-2.3.2-py3.10.egg-info /opt/ros/humble/local/lib/python3.10/dist-packages/interactive_markers/init.py
/opt/ros/humble/local/lib/python3.10/dist-packages/interactive_markers/interactive_marker_server.py
/opt/ros/humble/local/lib/python3.10/dist-packages/interactive_markers/menu_handler.py
/opt/ros/humble/local/lib/python3.10/dist-packages/interactive_markers-2.3.2-py3.10.egg-info/PKG-INFO
/opt/ros/humble/local/lib/python3.10/dist-packages/interactive_markers-2.3.2-py3.10.egg-info/SOURCES.txt
/opt/ros/humble/local/lib/python3.10/dist-packages/interactive_markers-2.3.2-py3.10.egg-info/dependency_links.txt
/opt/ros/humble/local/lib/python3.10/dist-packages/interactive_markers-2.3.2-py3.10.egg-info/top_level.txt
/opt/ros/humble/local/lib/python3.10/dist-packages/visualization_msgs/srv/_get_interactive_markers.py
/opt/ros/humble/local/lib/python3.10/dist-packages/visualization_msgs/srv/_get_interactive_markers_s.c
/opt/ros/humble/share/interactive_markers
/opt/ros/humble/share/ament_index/resource_index/package_run_dependencies/interactive_markers
/opt/ros/humble/share/ament_index/resource_index/packages/interactive_markers
/opt/ros/humble/share/ament_index/resource_index/parent_prefix_path/interactive_markers
/opt/ros/humble/share/interactive_markers/cmake
/opt/ros/humble/share/interactive_markers/environment
/opt/ros/humble/share/interactive_markers/local_setup.bash
/opt/ros/humble/share/interactive_markers/local_setup.dsv
/opt/ros/humble/share/interactive_markers/local_setup.sh
/opt/ros/humble/share/interactive_markers/local_setup.zsh
/opt/ros/humble/share/interactive_markers/package.dsv
/opt/ros/humble/share/interactive_markers/package.xml
/opt/ros/humble/share/interactive_markers/cmake/ament_cmake_export_dependencies-extras.cmake
/opt/ros/humble/share/interactive_markers/cmake/ament_cmake_export_targets-extras.cmake /opt/ros/humble/share/interactive_markers/cmake/export_interactive_markersExport-none.cmake
/opt/ros/humble/share/interactive_markers/cmake/export_interactive_markersExport.cmake
/opt/ros/humble/share/interactive_markers/cmake/interactive_markersConfig-version.cmake
/opt/ros/humble/share/interactive_markers/cmake/interactive_markersConfig.cmake
/opt/ros/humble/share/interactive_markers/environment/ament_prefix_path.dsv
/opt/ros/humble/share/interactive_markers/environment/ament_prefix_path.sh
/opt/ros/humble/share/interactive_markers/environment/path.dsv
/opt/ros/humble/share/interactive_markers/environment/path.sh
/opt/ros/humble/share/interactive_markers/environment/pythonpath.dsv
/opt/ros/humble/share/interactive_markers/environment/pythonpath.sh
Thanks for any advice!
. I would expect something likecd ~/ws_rviz2 && source ./devel/setup.bash && ros2 run rviz2 rviz2
or wherever you've built rviz2 if not~/ws_rviz2
. It seems like you have duplicate copies of your rviz installed somehow and that may be how you're getting collisions on the plugins? $\endgroup$
