Hi can someone help me to find out what the unit of measuremnt of the distance variable in this code is? I'm using it to control a ur10:
//-------------- Längenberechnung der Trajectorie-----------------------------------------
double calculateDistance(const std::vector<double>& p1, const std::vector<double>& p2)
if (p1.size() != p2.size())
RCLCPP_ERROR(rclcpp::get_logger("EndEffectorIkSolverNode"), "Gelenkpunkt-Dimensionen stimmen nicht überein");
return 0.0;
double distance = 0.0;
for (size_t i = 0; i < p1.size(); ++i)
distance += std::abs(p1[i] - p2[i]);
return distance;
//------------Callabkc wenn eine PSoe erhalten worden ist--------------------------------
void poseCallback(const geometry_msgs::msg::Point::SharedPtr msg,
moveit::planning_interface::MoveGroupInterface& move_group_interface,
rclcpp::Publisher<std_msgs::msg::Bool>::SharedPtr planningResultPub,
rclcpp::Publisher<std_msgs::msg::Bool>::SharedPtr executionResultPub,
rclcpp::Publisher<std_msgs::msg::Float64>::SharedPtr planningTimePub,
rclcpp::Publisher<std_msgs::msg::Float64>::SharedPtr executionTimePub,
rclcpp::Publisher<std_msgs::msg::Float64>::SharedPtr planningAttPub,
rclcpp::Publisher<std_msgs::msg::Float64>::SharedPtr planLenPub) {
// Setzen der Zeilpose
geometry_msgs::msg::Pose target_pose;
target_pose.position.x = msg->x;
target_pose.position.y = msg->y;
target_pose.position.z = msg->z;
// setzen der Orientierung für "wrist_3_link" mittels quaternion
tf2::Quaternion quaternion;
quaternion.setRPY(M_PI, 0.0, -M_PI_2);
target_pose.orientation.x = quaternion.getX();
target_pose.orientation.y = quaternion.getY();
target_pose.orientation.z = quaternion.getZ();
target_pose.orientation.w = quaternion.getW();
move_group_interface.setPoseTarget(target_pose);
// planen einer trajectorie
bool success = false;
moveit::planning_interface::MoveGroupInterface::Plan plan;
const int max_attempts = 10; // Maximalanzahl an Plaungsversuchen
for (int attempt = 0; attempt < max_attempts && !success; ++attempt) {
RCLCPP_INFO(rclcpp::get_logger("EndEffectorIkSolverNode"), "Planung gescheitert Versuch: %d", attempt);
std::tie(success, plan) = [&move_group_interface]() -> std::pair<bool, moveit::planning_interface::MoveGroupInterface::Plan> {
moveit::planning_interface::MoveGroupInterface::Plan msg;
auto const ok = static_cast<bool>(move_group_interface.plan(msg));
return std::make_pair(ok, msg);
if (!success) {
RCLCPP_ERROR(rclcpp::get_logger("EndEffectorIkSolverNode"), "Planung gescheitert!");
} else {
// Extract planning time from the plan
double planning_time = plan.planning_time_;
// Publish planning time
std_msgs::msg::Float64 planningTimeMsg;
planningTimeMsg.data = planning_time;
planningTimePub->publish(planningTimeMsg);
std_msgs::msg::Float64 planningAttMsg;
planningAttMsg.data = attempt+1;
planningAttPub->publish(planningAttMsg);
double total_distance = 0.0;
for (size_t i = 1; i < plan.trajectory_.joint_trajectory.points.size(); ++i)
total_distance += calculateDistance(plan.trajectory_.joint_trajectory.points[i-1].positions, plan.trajectory_.joint_trajectory.points[i].positions);
std_msgs::msg::Float64 planLengthMsg;
planLengthMsg.data = total_distance;
planLenPub->publish(planLengthMsg);
std_msgs::msg::Bool planningResultMsg;
planningResultMsg.data = success;
planningResultPub->publish(planningResultMsg);
// Wenn es einen Plan gibt ausführen
if (success){
double execution_duration = 0.0;
auto execute_start_time = std::chrono::high_resolution_clock::now();
moveit::core::MoveItErrorCode result = move_group_interface.execute(plan);
auto execute_end_time = std::chrono::high_resolution_clock::now();
execution_duration = std::chrono::duration<double>(execute_end_time - execute_start_time).count();
// Publish execution time
std_msgs::msg::Float64 executionTimeMsg;
executionTimeMsg.data = execution_duration;
executionTimePub->publish(executionTimeMsg);
if (result == moveit::core::MoveItErrorCode::SUCCESS){
RCLCPP_INFO(rclcpp::get_logger("EndEffectorIkSolverNode"), "Geplante Bewegung ausgeführt");
} else {
RCLCPP_ERROR(rclcpp::get_logger("EndEffectorIkSolverNode"), "geplante Bewegung konnte nicht ausgeführt werden");
std_msgs::msg::Bool executionResultMsg;
executionResultMsg.data = (result == moveit::core::MoveItErrorCode::SUCCESS);
executionResultPub->publish(executionResultMsg);
} else {
RCLCPP_ERROR(rclcpp::get_logger("EndEffectorIkSolverNode"), "Planning failed!");
