i have a std::queue defined like this
std::queue<sensor_msgs::PointCloud2ConstPtr> pointCloudBuf;
I wanted to understand how to define this in ROS2 , i tried the following but
std::queue<sensor_msgs::msg::PointCloud2::ConstPtr> pointCloudBuf;
When trying to push to the queue
void velodyneHandler(const sensor_msgs::msg::PointCloud2::SharedPtr laserCloudMsg)
    mutex_lock.lock();
    pointCloudBuf.push(*laserCloudMsg);
    mutex_lock.unlock();
i am getting the following error
no matching function for call to ‘std::queue<std::shared_ptr<const sensor_msgs::msg::PointCloud2_<std::allocator<void> > > >::push(std::__shared_ptr_access<sensor_msgs::msg::PointCloud2_<std::allocator<void> >, __gnu_cxx::_S_atomic, false, false>::element_type&)’
   61 |     pointCloudBuf.push(*laserCloudMsg);
UPDATE
std::queue<sensor_msgs::msg::PointCloud2::SharedPtr> pointCloudBuf;
This seem to have solved my compilation issues , dont know if it will break something else down the line .
Anyhow , thankyou ROS community !
Originally posted by chrissunny94 on ROS Answers with karma: 142 on 2023-07-03
Try changing your declaration to the following. You've declared for ConstPtr but using for SharedPtr.
Originally posted by Gaurav Gupta with karma: 276 on 2023-07-03
Comment by Mike Scheutzow on 2023-07-03:
@chrissunny94: the problem is that your code has incompatible types for the queue and the callback argument.
Comment by chrissunny94 on 2023-07-04:
@Gaurav Gupta (small world!), thanks a lot . saw your answer just now . .
@Mike Scheutzow , yup looks like my code has a lot of incompatible types , sorting it now . Will post my finding soond .
Comment by chrissunny94 on 2023-07-05:
@Gaurav Gupta ,yup making it into shared_ptr , seems to have solved the problem . Someone in office also suggested the same solution .
Comment by Gaurav Gupta on 2023-07-05:
Yup! Glad it is all sorted now :)
