Hi, I am trying to rosmake the ar_kinect package on Ubuntu 11.10 and I get the following error. It is the last package I need to before running the mini_max grasp object tutorial, so any help would be appreciated. I also get a lot of warnings prior to the error, so I have included those as well. Thanks, -Scott
Full error: [ 50%] Building CXX object CMakeFiles/ar_kinect.dir/src/ar_kinect.o In file included from /home/scott/ros_packages/ar_kinect/include/ar_kinect/ar_kinect.h:52:0, from /home/scott/ros_packages/ar_kinect/src/ar_kinect.cpp:27: /opt/ros/fuerte/stacks/vision_opencv/cv_bridge/include/cv_bridge/CvBridge.h: In static member function ‘static sensor_msgs::Image_std::allocator<void >::Ptr sensor_msgs::CvBridge::cvToImgMsg(const IplImage*, std::string)’: /opt/ros/fuerte/stacks/vision_opencv/cv_bridge/include/cv_bridge/CvBridge.h:408:55: warning: ‘static bool sensor_msgs::CvBridge::fromIpltoRosImage(const IplImage*, sensor_msgs::Image&, std::string)’ is deprecated (declared at /opt/ros/fuerte/stacks/vision_opencv/cv_bridge/include/cv_bridge/CvBridge.h:307) [-Wdeprecated-declarations] /home/scott/ros_packages/ar_kinect/src/ar_kinect.cpp: In constructor ‘ar_pose::ARPublisher::ARPublisher(ros::NodeHandle&)’: /home/scott/ros_packages/ar_kinect/src/ar_kinect.cpp:62:75: warning: ‘sensor_msgs::CvBridge::CvBridge()’ is deprecated (declared at /opt/ros/fuerte/stacks/vision_opencv/cv_bridge/include/cv_bridge/CvBridge.h:64) [-Wdeprecated-declarations] /home/scott/ros_packages/ar_kinect/src/ar_kinect.cpp: In member function ‘void ar_pose::ARPublisher::getTransformationCallback(const PointCloud2ConstPtr&)’: /home/scott/ros_packages/ar_kinect/src/ar_kinect.cpp:230:7: error: ‘estimateRigidTransformationSVD’ is not a member of ‘pcl’ /home/scott/ros_packages/ar_kinect/src/ar_kinect.cpp:236:43: error: conversion from ‘tf::Matrix3x3’ to non-scalar type ‘btMatrix3x3’ requested /home/scott/ros_packages/ar_kinect/src/ar_kinect.cpp:237:44: error: conversion from ‘tf::Vector3’ to non-scalar type ‘btVector3’ requested /home/scott/ros_packages/ar_kinect/src/ar_kinect.cpp:254:34: warning: name lookup of ‘i’ changed [enabled by default] /home/scott/ros_packages/ar_kinect/src/ar_kinect.cpp:145:9: warning: matches this ‘i’ under ISO standard rules [enabled by default] /home/scott/ros_packages/ar_kinect/src/ar_kinect.cpp:239:15: warning: matches this ‘i’ under old rules [enabled by default] /home/scott/ros_packages/ar_kinect/src/ar_kinect.cpp:280:46: error: conversion from ‘tf::Transform’ to non-scalar type ‘btTransform’ requested make[3]: *** [CMakeFiles/ar_kinect.dir/src/ar_kinect.o] Error 1 make[3]: Leaving directory /home/scott/ros_packages/ar_kinect/build' make[2]: *** [CMakeFiles/ar_kinect.dir/all] Error 2 make[2]: Leaving directory /home/scott/ros_packages/ar_kinect/build' make[1]: *** [all] Error 2 make[1]: Leaving directory `/home/scott/ros_packages/ar_kinect/build'
[ rosmake ] Output from build of package ar_kinect written to: [ rosmake ] /home/scott/.ros/rosmake/rosmake_output-20120718-115102/ar_kinect/build_output.log [rosmake-2] Finished <<< ar_kinect [FAIL] [ 8.44 seconds ]
[ rosmake ] Halting due to failure in package ar_kinect.
Originally posted by Scott on ROS Answers with karma: 693 on 2012-07-18
This error most likely has to do with changes to the tf datatypes for fuerte as described in this migration guide. If there is no migrated version available, you probably have to fix the package yourself for fuerte.
Originally posted by Stefan Kohlbrecher with karma: 24361 on 2012-07-18
Comment by Procópio on 2012-11-19:
in the page you mentioned, I solved my problems running the scritpt: rosrun tf bullet_migration_sed.py
For anyone else having this trouble, I submitted a patch to fergs' google code site. It got everything working for me.
Originally posted by Jeffrey Kane Johnson with karma: 452 on 2012-07-24
