Hello, I am trying to install Moveit with the version kinetic, when I type: frauas@frauas-Kinetic:~/ws_moveit$ rosdep install -y --from-paths . --ignore-src --rosdistro kinetic I received the error:
ERROR: the following packages/stacks could not have their rosdep keys resolved to system dependencies:
franka_example_controllers: Cannot locate rosdep definition for [libfranka] franka_gazebo: Cannot locate rosdep definition for [control_toolbox]: franka_visualization: Cannot locate rosdep definition for [libfranka]: franka_hw: Cannot locate rosdep definition for [libfranka] franka_control: Cannot locate rosdep definition for [libfranka] moveit_tutorials: Cannot locate rosdep definition for [joy] franka_gripper: Cannot locate rosdep definition for [libfranka]
Doing frauas@frauas-Kinetic:~/ws_moveit/src$ ls
franka_ros moveit_tutorials realtime_tools graph_msgs moveit_visual_tools ros_control libfranka panda_moveit_config rviz_visual_tools with "libfranka" inside, I do not where it should be.
I have follow the steps of: http://docs.ros.org/en/kinetic/api/moveit_tutorials/html/doc/getting_started/getting_started.html#build-your-catkin-workspace
Thank you in advance for your help.
Originally posted by onkheisen on ROS Answers with karma: 21 on 2022-05-04
Have you tried building the franka_ros packages?
E.g. with these steps there: https://frankaemika.github.io/docs/installation_linux.html#installing-from-the-ros-repositories
What errors do you see there?
Do you have these installed
sudo apt-get install ros-kinetic-ros-control ros-kinetic-ros-controllers
sudo apt-get install ros-kinetic-gazebo-ros-control
Originally posted by ljaniec with karma: 3064 on 2022-05-04
Comment by Joe28965 on 2022-05-04:
Would it have something to do with kinetic being EOL? Doesn't rosdep update skip EOL distributions?
EDIT in that case, they should try rosdep update --include-eol-distros and try again to run rosdep install --from-paths src --ignore-src -r -y
Comment by ljaniec on 2022-05-05:
I didn't know this flag --include-eol-distros for rosdep, thank you :) It's worth a shot for sure!
Comment by onkheisen on 2022-05-05:
@Joe28965 was right, I tryed with rosdep update --include-eol-distros and later again with my rosdep install -y --from-paths . --ignore-src --rosdistro kinetic again and it was fixed. I will study what EOL distributions are.
Thank you so much to both of you, have a nice day.
EOL means End Of Life - http://wiki.ros.org/Distributions It's not longer actively supported. You can accept this answer and upvote comments to let others see that it's solved
Comment by onkheisen on 2022-05-06:
Thanks @ljaniec
