i try to build new package for working with ros and gazebo with
catkin_create_pkg spcbot_description tf rviz gazebo xacro urdf rospy roscpp std_msgs geometry_msgs
but after i run catkin_make i get
 +++ processing catkin package: 'spcbot_description'
 -- ==> add_subdirectory(spcbot/spcbot_description)
 CMake Warning at /opt/ros/kinetic/share/catkin/cmake/catkinConfig.cmake:76 (find_package):
   Could not find a package configuration file provided by "gazebo" with any
   of the following names:
     gazeboConfig.cmake
     gazebo-config.cmake
   Add the installation prefix of "gazebo" to CMAKE_PREFIX_PATH or set
   "gazebo_DIR" to a directory containing one of the above files.  If "gazebo"
   provides a separate development package or SDK, be sure it has been
   installed.
   spcbot/spcbot_description/CMakeLists.txt:10 (find_package)
 -- Could not find the required component 'gazebo'. The following CMake error indicates that you either need to install the                package with the same name or change your environment so that it can be found.
 CMake Error at /opt/ros/kinetic/share/catkin/cmake/catkinConfig.cmake:83 (find_package):
     gazeboConfig.cmake
     gazebo-config.cmake
   installed.
 See also "/home/zora/tuto_catkin_ws/build/CMakeFiles/CMakeOutput.log".
 See also "/home/zora/tuto_catkin_ws/build/CMakeFiles/CMakeError.log".
 Makefile:556: recipe for target 'cmake_check_build_system' failed
 make: *** [cmake_check_build_system] Error 1
 Invoking "make cmake_check_build_system" failed
there are any solution ???
Originally posted by zahra on ROS Answers with karma: 1 on 2019-10-21
You need gazebo installed.
sudo apt install ros-kinetic-gazebo*
Originally posted by stevemacenski with karma: 8272 on 2019-10-21
Comment by zahra on 2019-10-21:
i installed i have gazebo7
Comment by stevemacenski on 2019-10-21:
either you didnt install it where it can be found or you have an incomplete environment to find it. The error is pretty clear.
sir i was used
curl -sSL http://get.gazebosim.org | sh
to install gazebo should i following the Alternative installation ??
Try to use the instructions above
do you mean this
