I am getting an error when I give this command rosdep install --from-paths ./ -i -y --rosdistro melodic
WARNING: given --rosdistro melodic but ROS_DISTRO is "kinetic". Ignoring environment.
WARNING: ROS_PYTHON_VERSION is unset. Defaulting to 2
ERROR: the following packages/stacks could not have their rosdep keys resolved to system dependencies:
How can I resolve this?
package.xml
content. And also how you have setup your rosdep sources. I'll note that you also appear to have kinetic in your environment but you're trying to do things with Melodic. This may cause you problems and you may want to remove kinetic from your environment before trying to do more with melodic. $\endgroup$
