Hello, i tried to install ROS on my Raspberry pi 3 and have problems with setting up the key. I am running Ubuntu server 20.04 on my Raspberry pi. i control it via ssh connection from my laptop.
and try to install ros by following the roswiki instructions.
i can't get very far because i can't set up the key in step 1.3 correctly.
I am using the following line: curl -s https://raw.githubusercontent.com/ros/rosdistro/master/ros.asc | sudo apt-key add -
and get this output: gpg: no valid OpenPGP data found.
I am not very familiar with these stuff. Do I need to pre-install something for this to work? or is the key on the roswiki homepage not up to date?
thank you in advance!
Originally posted by Musab.c on ROS Answers with karma: 16 on 2021-07-19
Comment by mgruhler on 2021-07-20:
Please double-check:
  1. is curl installed on the server? If I'm not mistaken, it does not come preinstalled on (at least) the server version of 20.04. You should receive a Command not found error a few lines above the error you show)
  2. If it is installed, are you behind a proxy? Does just the first part (i.e. only the curl -s http...) command print a key to the command line? If not, what error do you get?
I solved the problem, it turned out that the ip address of my Raspberry pi was the truble maker. i have created a static ip for my ssh connection. Now every thing is working. But thanks for your reply.
Originally posted by Musab.c with karma: 16 on 2021-07-20
