Hi,
I have some developments that I want to test on the following Fanuc robot R-2000iC/210F
. I have found that fanuc experimental lists a support package fanuc_r2000ic_support
. This package contains configuration data, 3D models and launch files for Fanuc R-2000iC manipulators. Can I use moveit setup assistant, loading the urdf from ~/catkin_ws/src/fanuc_experimental/fanuc_r2000ic_support/urdf/r2000ic210f.xacro
, and following the steps on MSA wizard to generate moveit configuration pacakge for the /210F model?
thanks,
Zahid
Originally posted by zahid990170 on ROS Answers with karma: 135 on 2021-07-16
