I am trying to create a path for a robot to move a camera around an object at a specified distance and angle. I have a defined object_link with world as parent and I have a robot_base_link with world as parent as well. I have managed to create a path for robots tool0 around the object_link by looking up a transform between the object_link and tool0 for the current tool0 location as I am moving my robot by that. Then creating that as a PoseStamped pose, setting it to the required position around the object, then transforming that position to the robots reference frame and then moving the robot.
object_to_robot_transform = tfBuffer.lookupTransform("object_link", "tool0", ros::Time(0), ros::Duration(1.0));
scan_object = convert(object_to_robot_transform, scan_object);
set the poseStamped to required position
object_to_world_transform = tfBuffer.lookupTransform("world", "object_link", ros::Time(0));
tf2::doTransform(scan_object, scan_object, object_to_world_transform);
move_group.setPoseTarget(scan_object.pose);
move_group.move();
After these transforms, the pose in scan_object is the one I need the robot to move to (world,tool0).
But problems arise when I try to move a camera_frame that is at the end of the robot. My idea of how it would work was, that I would find the transformation between the object and camera(object,camera). Set the PoseStamped to the required position. Then transform it to (world,tool0).
object_to_camera_transform = tfBuffer.lookupTransform("object_link", "camera", ros::Time(0), ros::Duration(1.0));
convert object_to_camera_transform to poseStamped and set it to required position
robot_to_object_transform = tfBuffer.lookupTransform("tool0", "object_link", ros::Time(0), ros::Duration(1.0));
tf2::doTransform(scan_object, scan_object, robot_to_object_transform);
camera_to_world_transform = tfBuffer.lookupTransform("camera", "world", ros::Time(0), ros::Duration(1.0));
tf2::doTransform(scan_object, scan_object, camera_to_world_transform);
move_group.move();
But sadly, this does not give me the results I'm going for so I was wondering if there is a better method of transforming, maybe with only one transform operation?
P.S. I am aware of changing the tip_link in the .srdf file to the camera frame, but that would make this very tedious for usability. P.P.S. This is my first question!
Originally posted by sniegs on ROS Answers with karma: 65 on 2021-03-24
As I have found out, doing transformations as suggested in my question isn't the best way to go about this problem and a better way is to add the camera_frame as a sort of gripper or just an end effector extension in the srdf file. So what you do is create a group in the srdf as such:
<group name="camera">
    <link name="camera_frame" />
</group>
and afterwards, define an end effector:
<end_effector name="camera_frame" parent_link="wrist_3_link" group="camera" parent_group="manipulator" />
The parent_link is the link of the robot, which the camera is attached to in the xacro/urdf. Now you can just set the end effector in code with
move_group.setEndEffectorLink("camera_frame");
and use a single transformation to move the camera around a point of interest.
Originally posted by sniegs with karma: 65 on 2021-06-08
