Hi,
I want to extract some lists with double values.
Because it is a nested array, it is not readable with NodeHandle getParam?
ros::NodeHandle nh;
XmlRpc::XmlRpcValue box;
nh.getParam("test/values", box);
if(box.getType() == XmlRpc::XmlRpcValue::Type::TypeArray && box.size() > 0 )){
    if(box[0].getType() == XmlRpc::XmlRpcValue::Type::TypeArray && box[0].size() > 0){
        for(int i = 0; i < box[0].size(); i++) {
                  ROS_INFO("value %f ",box[0][i]);
yaml file:
test:
  values:
  - [  0.0,  0.1,  0.2]
  - [  0.0,   -0.1,  -0.2]
At this point, how can I get the double value?
Error message:
warning: format ‘%f’ expects argument of type ‘double’, but argument 8 has type ‘XmlRpc::XmlRpcValue’ [-Wformat=]
box[0][i].getDoubleFormat() returned %.16g, so it should be correct.
But an assert failed with
ROS_ASSERT(box[0][i].getType() == XmlRpc::XmlRpcValue::TypeDouble);
Originally posted by zFnq9 on ROS Answers with karma: 3 on 2020-04-19
The first thing that you need is to change the way you wrote the YAML file.
 test:
  values0: [  0.0,  0.1,  0.2]
  values1: [  0.0,   -0.1,  -0.2]
To something like that, each array has a name.
1| ros::NodeHandle node;
2| std::vector<double> vectorVar;
3| node.getParam("test/values0", vectorVar);
And for each array, you must repeat step 2 and 3, or create a vector of a vector.
Let me aware if it is working, I tried this solution here before, but we never know.
Originally posted by Teo Cardoso with karma: 378 on 2020-04-20
Comment by zFnq9 on 2020-04-20:
Thanks! With this method, do I need each name for getParam ("values0", "values1, ...") ? It should handle different length.
Comment by Teo Cardoso on 2020-04-20:
Yes. however, the syntax isn't exactly this one. Should be this one: node.getParam(PARAM_NAME, VARIABLE)
So if you have more than one array in the YAML file. You should do something like this:
node.getParam("test/value0", value0Vector);
node.getParam("test/value1", value1Vector);
node.getParam("test/value2", value2Vector);
But you always can use loop statements to make this smart.
std::vector<std::vector<double>> vectorVar
for(int index = 0; ros::param::has("test/values" + std::to_string(index)); index++) {
    std::vector<double> tempVector;
    node.getParam("test/values" + std::to_string(index), tempVector);
    vectorVar.push_back(tempVector);
Instead of using a tempVector you could resize your vector ( if the number of elements is known) and use vectorVar.at(index)
And there aren't problems arrays have a different number of elements.
