Edit:
just checked and apparently rosinstall_generator
accepts an ALL
argument that: "specif[ies] all release packages":
pkgname catkin package names, rosbuild stack names or variant
names. Use 'RPP' to specify all packages available in
the current environment. Use 'ALL' to specify all
release packages (only usable as a single argument).
Running the following command gets me a .rosinstall
file with approx 500 KB of info on all released packages in ROS Kinetic:
rosinstall_generator --rosdistro=kinetic --deps --tar ALL > all.rosinstall
Note that this also includes information on their dependencies. Adding --deps
is probably not needed, as they can only depend on other ROS packages or system dependencies, and all ROS packages are already in the selection, but it won't hurt.
Note: this gets you a .rosinstall
file for all packages at the currently released version (ie: released as of when you invoke that command).
For ROS2, you can clone all registered packages with a simple command: [..] How can you do the same for the ROS 1 package listed in this yaml file: https://github.com/ros/rosdistro/blob/master/melodic/distribution.yaml
I don't believe there is tooling that will "clone all registered packages" for you. Or at least, not directly with/from that particular .yaml
file. The ros2.repos
file does not contain the same sort of abstractions / information as the distribution.yaml
The former is a plain listing of repositories that vcs
can clone for you (using git
or another vcs tool), while distribution.yaml
contains all sorts of meta-data about packages and repositories.
rosinstall_generator can use that information to generate a .rosinstall
file for you that is (at least conceptually) the same as the ros2.repos
file: .rosinstall
files contain the same sort of information, but are typically consumed by wstool
(vcs
can also consume them).
As distribution.yaml
is a plain .yaml
file, you could consider creating a simple Python script that loads it and then uses the release
dicts in it to clone a specific version of all packages registered for that distribution. I'm not aware of a tool that does this already, as it's not a typical use of distribution.yaml
If you'd like to do things a little more structured, you could actually use rosinstall_generator to generate .rosinstall
files specifically for a set of packages (so including their (transitive) dependencies).
You may actually be able to get rosinstall_generator
file for all packages in the distribution.yaml
though, by using certain parameters. I haven't checked whether that is possible.
Originally posted by gvdhoorn with karma: 86574 on 2018-12-18
Comment by gvdhoorn on 2018-12-18:
This is (somewhat) related to the work we're doing with the rosinstall_generator_time_machine, but there we go back in time first and then generate .rosinstall
files.
