I am attempting to build the Universal Robots ROS Driver on ROS Melodic Ubutnu 18.04, but when I try to build the workspace with catkin_make
I get the error below. What can I do to solve this? Thank you
[ 77%] Building CXX object fmauch_universal_robot/ur_kinematics/CMakeFiles/ur10_moveit_plugin.dir/src/ur_moveit_plugin.cpp.o
In file included from /home/<user>/catkin_ws/src/fmauch_universal_robot/ur_kinematics/src/ur_moveit_plugin.cpp:75:0:
/opt/ros/melodic/include/class_loader/class_loader.h:36:2: warning: #warning Including header <class_loader/class_loader.h> is deprecated, include <class_loader/class_loader.hpp> instead. [-Wcpp]
#warning Including header <class_loader/class_loader.h> is deprecated, \
c++: internal compiler error: Killed (program cc1plus)
Please submit a full bug report,
with preprocessed source if appropriate.
See <file:///usr/share/doc/gcc-7/README.Bugs> for instructions.
fmauch_universal_robot/ur_kinematics/CMakeFiles/ur10_moveit_plugin.dir/build.make:62: recipe for target
'fmauch_universal_robot/ur_kinematics/CMakeFiles/ur10_moveit_plugin.dir/src/ur_moveit_plugin.cpp.o' failed
make[2]: ***
[fmauch_universal_robot/ur_kinematics/CMakeFiles/ur10_moveit_plugin.dir/src/ur_moveit_plugin.cpp.o] Error 4
CMakeFiles/Makefile2:4448: recipe for target
'fmauch_universal_robot/ur_kinematics/CMakeFiles/ur10_moveit_plugin.dir/all' failed
make[1]: *** [fmauch_universal_robot/ur_kinematics/CMakeFiles/ur10_moveit_plugin.dir/all] Error 2
Makefile:140: recipe for target 'all' failed
make: *** [all] Error 2
Invoking "make -j1 -l1" failed
Originally posted by Vuro H on ROS Answers with karma: 27 on 2020-04-01
