I have dowloaded the Universal Robots (UR3, UR5 and UR10) from:
http://wiki.ros.org/universal_robot
I am trying to load the Urdf | xacro file in Moveit setup assistant...However I cannot load the robot
The error msg in Movelt Apl is "URDF/COLLADA file is not a valid robot model."
And the terminal returns me the following message: "No name given for the robot"
I followed the "tutorial" given by the link above...I executed the commands:
rosdep update....rosdep install rosdistro etc... and source ...devel/bash..
I also dowloaded the package with the Abb robots....and there was no problem in load them in Moveit. However I need a robot with ee_effector to follow the tutorial from qbotics...Lenthin Joseph...form the book Mastering ROS... anyway when I was finishing the setup from Abb robot moveit stopped and a shadow color appeared..it stopped to work, I don't know why. I would like to load the ur10 robot!
obs: I have already looked the answers similar to this issue in Forum, however they did not adressed my case!
Could someone help me to find the error?
Thanks in advance
Originally posted by Vini71 on ROS Answers with karma: 266 on 2019-07-01
The answer you've posted is actually not the answer.
Those files are used by thousands of people and they are correct as-is.
The cause of your problem is that you've selected the wrong file to load.
Instead of loading ur10e.urdf.xacro, you should load the ur10e_robot.urdf.xacro file.
The former only defines the macro, but doesn't instantiate it. The latter is a top-level xacro that includes the appropriate files and then also instantiates the model.
Loading a file that only defines a macro will result in an empty file after the MSA tries to load it, hence the error.
Originally posted by gvdhoorn with karma: 86574 on 2019-07-01
