Hey!
I had successfully created a working URDF file for the UR5 robot with a Kinect sensor attached to the end-effector. I have verified the URDF file using check_urdf. I wished to use the URDF file with Gazebo as well as RViz, for which I was following this link. I am using ROS Kinetic with Ubuntu 16.04.
For creation of the MoveIt! configuration package, I was referring to MoveIt setup assistant tutorial, this tutorial and the ROS Industial tutorial.
I have created the self-collision matrix and the virtual joints as per the ROS-I tutorial. The ROS-I suggested that I add the planning group with the name 'manipulator' and by adding a Kinematic chain from the base_link to the tool0 (end-effector) link. However when I try to add robot poses with this planning group, I get this following error message.
Unable to find joint model group for group: manipulator Are you sure this group has associated joints/links?
Because of this, I was not able to visualise the joint motions as well as set a pose. Any particular reason for this error? I have attached the related pictures for reference. Thanks in advance.
Self Collision checking
Virtual Joints
Planning Groups_General
Planning_Groups_2
Edit: I have checked the same procedure with standard URDF files from the UR5 and UR10 robot. I am still getting the same error.
Update: Added the link to the URDF file
https://drive.google.com/file/d/1_6DP_EUM1Y2F6r3TWuw4ewi-PQp1AUAe/view
Originally posted by aaditya_saraiya on ROS Answers with karma: 105 on 2018-05-12
Solved it. Turns out it was a stupid mistake. While making the new planning group, I was adding an extra space at the end of the planning group name 'manipulator' which was causing an error and showing that this particular planning group doesn't exist.
Originally posted by aaditya_saraiya with karma: 105 on 2018-05-13
