We have three physical machines: A, B and logger. A and B actively publish to various topics and logger subscribes to everything that A and . The plan is to network them together through a single router/switch running DHCP.
My understanding of how ROS on top of DHCP will work is that each time A publishes to a topic that B and logger are subscribed to - the information in that message will be encoded into TCP packets and transmitted to the router/switch twice - once for each subscribing machine’s IP address.
This strikes me as rather wasteful - a more efficient, ideal situation would be: A publishes to a topic, the message is encoded into TCP packets with the subnet broadcast address, this packet transmits once to the router/switch and is relayed to both B and logger. Given that 100% of messages being sent over the network should be received by every other machine on the network this would double the effective available bandwidth.
Could such a networking scheme be practically configured and if so, how?
Originally posted by LukeAI on ROS Answers with karma: 131 on 2019-03-21
Comment by gvdhoorn on 2019-03-21:\
should this read: "on top of TCP"?
Also note: if that is the case, then it's only partly correct: ROS supports both UDP and TCP (although UDP support in rospy
is not complete).
minimise packet broadcast redundancies
As broadcasting is not used in the default ROS transports, I'm wondering what you mean by this.
