I am trying to run the externalcontrol node on the UR5 robot, but I get the following message:
"The connection to the remote PC could not be established"
Things to note:
  • I calibrated my robot before starting ur_robot_driver on my PC
  • After starting ur_robot_driver (and MoveIt) I see the correct state of the physical robot in Rviz
  • I doublechecked the IP-address of my ROS PC in externalcontrol under the installation tab on the tablet
Robot specifications:
  • UR5
  • CB3.0 controller
  • PolyScope 3.9.1
  • External Control URcap version 1.0.1
ROS PC specifications:
  • Ubuntu 16.04 Xenial
  • ROS Kinetic
  • ur_robot_driver version 0.0.3
What did I wrong? The ROS driver is running on the pc and the host IP address is correct.
EDIT: ip_addr_show outputs this:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: wlp3s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
    link/ether 60:f6:77:99:da:e5 brd ff:ff:ff:ff:ff:ff
    inet 192.168.69.4/19 brd 192.168.95.255 scope global dynamic wlp3s0
       valid_lft 10244sec preferred_lft 10244sec
    inet6 fe80::ba57:b562:9c11:3b9b/64 scope link
3: enx3c18a078b201: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether 3c:18:a0:78:b2:01 brd ff:ff:ff:ff:ff:ff
    inet 192.168.1.100/24 brd 192.168.1.255 scope global dynamic enx3c18a078b201
       valid_lft 86378sec preferred_lft 86378sec
    inet6 fe80::13f6:65f:11df:fc3e/64 scope link
Originally posted by krablander on ROS Answers with karma: 19 on 2020-01-09
Comment by gvdhoorn on 2020-01-09:
Could you tell us whether you have a firewall enabled? And whether you are running Ubuntu natively, or in a VM?
probably, but please show us the IPs and network settings of the hosts involved.
Comment by krablander on 2020-01-09:
The firewall is disabled. I am running Ubuntu natively on the PC (dualboot with windows).
  • IP-address of the host pc: 192.168.69.4 (DHCP, found by command hostname -I)
  • IP-address of the robot: 192.168.1.200 (static)
Comment by gvdhoorn on 2020-01-09:\
please note that for multi-homed hosts this may not return the correct IP.
Could you show the output of ip addr show?
And UniversalRobots/Universal_Robots_ROS_Driver#74 is a recent thread with a similar issue. See some of the later comments with steps to diagnose connection issues.
Given this: 192.168.69.4/19 I'm curious how you can access 192.168.1.200. Is there a (NAT) router between you and the robot? Can you show the output of: tracepath 192.168.1.200?
There is a router between the ROS PC and the robot. tracepath 192.168.1.200 outputs this:
1?: [LOCALHOST]                                         pmtu 1500
1:  192.168.1.200                                         3.091ms reached
1:  192.168.1.200                                         1.933ms reached
Resume: pmtu 1500 hops 1 back 1
What sort of router? Do you mean a switch? Because from the tracepath output it doesn't look like there is a router. I would've expected to see a hop between you and the robot in that case with a different IP address.
Could you tell us what sort of computers are involved? A laptop? A desktop PC? Is there a wireless link involved?
Could you also login to the robot (using SSH, user: root, pass: easybot) and try to ping 192.168.69.4? Also try: nc 192.168.69.4 50002 when you have the driver running on the ROS side. If that doesn't connect or time-out (it can take a while, up to 2.5 minutes), it would indicate something is blocking connections between the robot controller and the ROS PC.
Right now I believe you're using the wrong IP address for the reverse connection (ie: the one from the robot controller to the PC).
Originally posted by gvdhoorn with karma: 86574 on 2020-01-09
Comment by krablander on 2020-01-10:
I am using a linksys e1200 router. I am using a laptop with a USB-C -> ethernet adapter. There are no wireless links involved.
Laptop -> UTP cable -> router -> UTP cable -> UR5 robot
I pinged and nc'd 192.168.69.4 from the robot side, this gave me a time-out. However, after trying to ping another IP address 192.168.1.100, it was connecting.
So I changed the IP address from 192.168.69.4 to 192.168.1.100 in externalcontrol, the driver was running with no problems. I think the issue has been resolved. Thank you for your assistance.
Comment by Abdul Mannan on 2020-12-28:
I am having exactly the same problem. Also, when I run nc 192.168.0.77 50002 (my host IP address is 192.168.0.77), I get following error (UNKNOWN) [192.168.0.77] 50002 (?) : Connection refused. Any suggestion please?
Comment by AlexandrosNic on 2022-06-01:
I have the same problem. Connection refused. Did you find a solution?
