I have a UAV application and I am using Hector-SLAM for the navigation. I have got Hector-SLAM working with just the map, base link and laser frames but I would like to add a base_stabilised frame to read data from the IMU and correctly reference the base link.
I have set up a static transform between the base_stabilised and base_link frames (as below) but I have not managed to vary this transform based on data from the IMU.
image description
The topic with the IMU data is: "mavros/imu/data" and the message type is "sensor_msgs/Imu".
I have got the stabilized_to_link.py file to this stage but I don't know how to actually subscribe to the Imu data and create a transform from it. Please can someone help? Many Thanks!
import roslib
import rospy
import time
import tf
from sensor_msgs.msg import Imu
def publisher_of_tf():
rospy.init_node('imu_data_broadcaster', anonymous=True)
rate = rospy.Rate(10.0) #10Hz
imu_data = rospy.Subscriber("/mavros/imu/data", Imu) #Subscribes to /mavros/imu/data topic
br = tf.TransformBroadcaster()
    br.sendTransform((0.0, 0.0, 0.0),
                     (0.0, 0.0, 0.0, 1.0),
                     rospy.Time.now(),
         #child
                     "base_link",
         #parent
                     "base_stabilized")
         rate.sleep()
if __name__ == '__main__':
try:
    publisher_of_tf()
except rospy.ROSInterruptException:
    pass
Originally posted by SamH on ROS Answers with karma: 27 on 2020-02-25
Comment by MichaelDUEE on 2020-02-25:
I think you need to add a callback to your subscriber.
Comment by SamH on 2020-02-26:
Thanks for your suggestion. The file did originally contain a callback function and it prevented it from working which is why I took it out!
Without looking at the code, I think what you really want is the tree to be as it is, but remove the stabilized frame as a child of map.
If you have the stabilized frame there, then the normal base link frame has to go through a reduction in dimensionality and add it back in for 3D orientation.
Instead, add the stabilized frame as a child of the base link, so it now has 2 children: laser and stabilized. Then you can take the 3DOF pose in base link and then "stabilize" it as a frame of its own.
Originally posted by stevemacenski with karma: 8272 on 2020-02-25
Thank you for your answer. What do you mean when you say that the base_link frame has to go through a reduction in dimensionality? I have set up the co-ordinate frames as exampled in the "How to set up hector_slam for your robot" page on the ROS Wiki website:
link text
If the data from the Lidar scanner doesn't go through the base_stabilized frame then how can it be corrected before it is mapped? Sorry for my ignorance!
Although I have not written a python code to implement this myself, I did find the hector_imu_attitude_to_tf package was able to achieve what I was looking to do. If anyone else is trying to do it then it's available here:
link text
I found that the Launch file needed modifying to remap the topics I was working with. I hope this helps someone else!
Originally posted by SamH with karma: 27 on 2020-02-28
