I ran into an issue while trying to compile with catkin which was recently solved and merged to the distro's kinetic-devel
branch. It is issue #955, which was added to catkin's 0.7.15 release about a week ago, which was followed by 0.7.16 a few days later. As the issue is now solved, I thought that just upgrading the package would let me compile without problem. However, after running
apt-get update
I checked the latest version of ros-kinetic-catkin
and got the following
sudo apt-cache policy ros-kinetic-catkin
ros-kinetic-catkin:
Installed: 0.7.14-0xenial-20180809-132632-0800
Candidate: 0.7.14-0xenial-20180809-132632-0800
Version table:
*** 0.7.14-0xenial-20180809-132632-0800 500
500 http://packages.ros.org/ros/ubuntu xenial/main amd64 Packages
100 /var/lib/dpkg/status
which indicates that the latest version is 0.7.14. However, the ros/catkin api webpage clearly shows "catkin 0.7.16 documentation" on top. I would like to upgrade to version 0.7.16 without compiling from source, so:
- Do I have to make some dependency changes in order to update the package?
- Shouldn't
apt-get update && apt-get upgrade ros-kinetic-catkin
do it or is there something I'm missing?
As a side note, I'm a bit confused as how the repository and the dependencies relate to each other, so maybe it's just that the dependencies do not point to the latest relase? Correct me if I'm wrong as this is a field I know nothing about...
Originally posted by jgallostra on ROS Answers with karma: 30 on 2019-03-15
