Dear All,
I tried to create a catkin ws using catkin init
then enter catkin build
and I got the following error:
emeric@emeric-desktop:~/catkin_planning_ws$
ls src hector_navigation waypoint_ctl
catkin build
Profile: default
Extending: [env] /home/emeric/catkin_wsp/devel:/opt/ros/kinetic
Workspace: /home/emeric
Source Space: [exists] /home/emeric/src
Log Space: [missing] /home/emeric/logs
Build Space: [exists] /home/emeric/build
Devel Space: [exists] /home/emeric/devel
Install Space: [unused] /home/emeric/install
DESTDIR: [unused] None
Devel Space Layout: linked
Install Space Layout: None
Additional CMake Args: DCMAKE_BUILT_TYPE=Release
Additional Make Args: None
Additional catkin Make Args: None
Internal Make Job Server: True
Cache Job Environments: False
Whitelisted Packages: None
Blacklisted Packages: None
Workspace configuration appears valid.
File "/usr/bin/catkin", line 9, in <module>
load_entry_point('catkin-tools==0.4.4','console_scripts', 'catkin')() File "/usr/lib/python2.7/dist-packages/catkin_tools/commands/catkin.py", line 267, in main
catkin_main(sysargs)
File "/usr/lib/python2.7/dist-packages/catkin_tools/commands/catkin.py",line 262, in catkin_main sys.exit(args.main(args) or 0)
File "/usr/lib/python2.7/dist-packages/catkin_tools/verbs/catkin_build/cli.py", line 420, in main summarize_build=opts.summarize # Can be True, False, or None File
"/usr/lib/python2.7/dist-packages/catkin_tools/verbs/catkin_build/build.py", line 283, in build_isolated_workspace
workspace_packages = find_packages(context.source_space_abs,exclude_subspaces=True, warnings=[])
File "/usr/lib/python2.7/dist-packages/catkin_pkg/packages.py",line 86, in find_packages:packages = find_packages_allowing_duplicates(basepath, find_packages_allowing_duplicates(basepath, exclude_paths=exclude_paths, exclude_subspaces=exclude_subspaces,warnings=warnings)
File "/usr/lib/python2.7/dist-packages/catkin_pkg/packages.py", line 146, in find_packages_allowing_duplicates xml, filename=filename, warnings=warnings)
File "/usr/lib/python2.7/dist-packages/catkin_pkg/package.py",line 509, in parse_package_string raise InvalidPackage('The manifest must contain a single "package" root tag')
catkin_pkg.package.InvalidPackage: The manifest must contain a single "package" root tag
Besides I do not understand why the workspace is set to /home/emeric and not /home/emeric/catkin_planning_ws ? Because the build
and devel
directories are created in /home/emeric.
Can you tell me what I am missing here?
Thank you very much
Originally posted by fabriceN on ROS Answers with karma: 59 on 2019-02-04
