Hello. How can i perform some actions after the program ends? I tried to use ROSInterruptException but it did not work.
!/usr/bin/env python
import rospy
def talker():
    pub = rospy.Publisher('chatter', String, queue_size=10)
    rospy.init_node('talker', anonymous=True)
    rate = rospy.Rate(10) # 10hz
        hello_str = "hello world %s" % rospy.get_time()
        rospy.loginfo(hello_str)
        pub.publish(hello_str)
        rate.sleep()
try:
    talker()
except rospy.ROSInterruptException:
    rospy.loginfo("TEST")
And when I do Ctrl+C the "TEST" line does not appear. What have I done wrong? Why the exception does not work?
Originally posted by kolyazoloto on ROS Answers with karma: 3 on 2018-11-27
You can register a callback for the shutdown hook in rospy as described here.
This shutdown even is called before the ros system closes so you should still be able to write log messages. Your code will look something like this:
import rospy
def talker():
        rate.sleep()
def my_shutdown_handler():
  print "shutdown time!"
  rospy.loginfo("test shutdown.")
try:
    rospy.on_shutdown(my_shutdown_handler)
    talker()
    pass
Originally posted by PeteBlackerThe3rd with karma: 9529 on 2018-11-28
Comment by kolyazoloto on 2018-11-28:
Thank you.
