My System Specifications ##
  1. Oracle VirtualBox
  2. Ubuntu 18.04
  3. ROS Melodic 1.14.3
  4. Host Computer- Windows 10 with Intel i7 and Nvidia 1660 graphics
I have been following the tutorials in the book "Mastering ROS for Robotics Programming" by Lentin Joseph. In chapter 2, for URDF tutorial, I did exactly follow the steps mentioned.
STEPS
  1. I created my pan & tilt model package inside the 'src' folder in my catkin workspace.
    ~/catkin_ws/src $ catkin_create_pkg pan_tilt_model roscpp rospy tf geometry_msgs urdf rviz xacro 2. Inside the pan_tilt_model package, I created three new folders, namely 'launch', 'meshes' and 'urdf'.<BR> ~/catkin_ws/src/pan_tilt_model $ mkdir meshes launch urdf
  2. Inside the 'urdf' folder, I created my URDF file named 'pan_tilt.urdf'
    ~/catkin_ws/src/pan_tilt_model/urdf $ gedit pan_tilt.urdf 4. Inside the 'launch' folder, I create my launch file named 'pan_tilt.launch'<BR> ~/catkin_ws/src/pan_tilt_model/launch $ gedit pan_tilt.launch
  3. I tried to run the 'roslaunch' command to run the launch file for the pan & tilt model
    ~/catkin_ws $ roslaunch pan_tilt_model pan_tilt.launch
Expected Outcome
Rviz should display my pan & tilt model in its display area along with a joint_state_publisher GUI.
Outcome I got
Rviz didn't display my model in its canvas. It just displayed a blank grid. Also, rviz was showing errors as
  • Global Status: Error
  • Fixed Frame- Fixed Frame [map] does not exist.
I have attached the screenshot the rviz window I am getting in the below link. rviz_window
Launch File 'pan_tilt.urdf'
<launch>
<arg name="model" />
<!-- Parsing xacro and setting robot_description parameter -->
<param name="robot_description" textfile="$(find pan_tilt_model)/urdf/pan_tilt.urdf" />
<!-- Setting gui parameter to true for display joint slider -->
<!-- Starting Joint state publisher node which will publish the joint values -->
<!-- Starting robot state publish which will publish tf -->
<node name="robot_state_publisher" pkg="robot_state_publisher" type="robot_state_publisher" />
<!-- Launch visualization in rviz -->
<node name="rviz" pkg="rviz" type="rviz" args="-d $(find pan_tilt_model)/urdf.rviz" required="true" />
    <node name="jsp_gui" pkg="joint_state_publisher_gui" type="joint_state_publisher_gui" />
</launch>
URDF File 'pan_tilt.urdf'
<?xml version="1.0"?>
<robot name="pan_tilt">
  <link name="dummy">
   </link>
  <joint name="dummy_joint" type="fixed">
     <parent link="dummy"/>
     <child link="base_link"/>
   </joint>
  <link name="base_link">
    <visual>
      <geometry>
    <cylinder length="0.01" radius="0.2"/>
      </geometry>
      <origin rpy="0 0 0" xyz="0 0 0"/>
      <material name="yellow">
        <color rgba="1 1 0 1"/>
      </material>
    </visual>
    <collision>
      <geometry>
    <cylinder length="0.03" radius="0.2"/>
      </geometry>
    </collision>
    <inertial>
    <mass value="1"/>
    <inertia ixx="1.0" ixy="0.0" ixz="0.0" iyy="1.0" iyz="0.0" izz="1.0"/>
    </inertial>
  </link>
  <joint name="pan_joint" type="revolute">
    <parent link="base_link"/>
    <child link="pan_link"/>
    <origin xyz="0 0 0.1"/>
    <axis xyz="0 0 1" />
    <limit effort="300" velocity="0.1" lower="-3.14" upper="3.14"/>
    <dynamics damping="50" friction="1"/>
  </joint>
  <link name="pan_link">
    <visual>
      <geometry>
    <cylinder length="0.4" radius="0.04"/>
      </geometry>
      <origin rpy="0 0 0" xyz="0 0 0.09"/>
      <material name="red">
        <color rgba="0 0 1 1"/>
      </material>
    </visual>
    <collision>
      <geometry>
    <cylinder length="0.4" radius="0.06"/>
      </geometry>
    </collision>
    <inertial>
    <mass value="1"/>
    </inertial>
  </link>
  <joint name="tilt_joint" type="revolute">
    <parent link="pan_link"/>
    <child link="tilt_link"/>
    <origin xyz="0 0 0.2"/>
    <axis xyz="0 1 0" />
    <limit effort="300" velocity="0.1" lower="-4.64" upper="-1.5"/>
  </joint>
  <link name="tilt_link">
    <visual>
      <geometry>
      </geometry>
      <origin rpy="0 1.5 0" xyz="0 0 0"/>
      <material name="green">
        <color rgba="1 0 0 1"/>
      </material>
    </visual>
    <collision>
      <geometry>
      </geometry>
    </collision>
    <inertial>
    <mass value="1"/>
    </inertial>
  </link>
</robot>
Originally posted by nilutpolkashyap on ROS Answers with karma: 3 on 2020-05-23
Please read: 7. Coordinate Frames and watch the video there. http://wiki.ros.org/rviz/UserGuide
Originally posted by Dragonslayer with karma: 574 on 2020-05-24
Comment by nilutpolkashyap on 2020-05-24:
Thanks a lot. It solved my problem.
Comment by Dragonslayer on 2020-05-28:
You are welcome. Please mark the answer as correct to keep answers.ros organized. thanks.
