I have a SICK encoder which works with CANOPEN protocol and also I have a KVASER leaf light v2 CAN to USB interface. So my question is if there is a way to use KVASER to read CANOPEN device? Maybe with ROS_CANOPEN package?
Originally posted by r.ghahremani on ROS Answers with karma: 18 on 2018-11-15
Yes, ros_canopen utilizes SocketCAN package and many Kvaser CAN interfaces, such as Leaf Light v2, are supported by SocketCAN. To install SocketCAN drivers for Kvaser hardware:
  • Make sure you uninstalled linuxcan (CANlib), since Kvaser drivers blacklist SocketCAN modules:
    • $ cd linuxcan - $ sudo make uninstall
  • Find your interface
    • ip a
Now you should see your Kvaser device listed, e.g.
- 3: can0: <NOARP,ECHO> mtu 16 qdisc noop state DOWN group default qlen 10 link/can
For the rest, I suggest you to consult https://answers.ros.org/question/250174/how-to-control-maxon-motor-by-using-ros_canopen/
Originally posted by speloot with karma: 46 on 2018-11-28
Comment by r.ghahremani on 2018-11-29:
Can you be specific? How should I do this?
Comment by speloot on 2018-12-10:
Just updated my previous response..
Comment by r.ghahremani on 2018-12-10:
@speloot, yup I found the answer pretty look like yours few days ago, was too busy to update here. After what you said, there is a configuration progress for ros canopen_chain_node after catching CAN data by ros socketcan_bridge.
