I'm attempting to get the output from a Kuebler 5868 draw wire encoder into ROS. The 5868 encoder is a CANOpen device that outputs the draw wire position over the CANbus.
My setup is Indigo running on Ubuntu 14.04 on a PC. Once I've decided between the two libraries I will be using a Raspberry Pi with Rasbian and a CAN shield to listen on the CANBus. My eventual goal is to broadcast the position of the draw wire so MoveIt can compute the extension of a hydraulic boom.
My difficulty at the moment is in working out whether I should be using ROS_canopen or kacanopen to interface with the encoder. I've been trying to understand how to use ROS_canopen for a few hours and haven't had a great deal of luck. Can anyone outline the key differences between these two packages and advise which will be easiest to work with?
EDIT:
Here's my launch file:
<launch>
<arg name="yaml" default="$(find extension_publisher)/draw_encoder.yaml" />
<node name="canopen_chain_node" pkg="canopen_chain_node" type="canopen_chain_node" output="screen"/>
</launch>
And here's my yaml:
bus:
device: can0 # socketcan network, this will require changing based on PLC config
master_allocator: canopen::ExternalMaster::Allocator
sync:
interval_ms: 10 # set to 0 to disable sync
overflow: 0 # overflow sync counter at value or do not set it (0, default)
nodes:
defaults: # optional, all defaults can be overwritten per node
eds_pkg: extension_publisher # optional package name for relative path
eds_file: "/kuebler_drivers/S58X8MT_HC.eds"
node1:
eds_file: "/kuebler_drivers/S58X8MT_HC.eds" #path to EDS/DCF file
publish: ["6004!"] #Position value
node2:
publish: ["6030!"] #Position value
Does that look about right? Thanks!
Originally posted by rmck on ROS Answers with karma: 147 on 2017-03-20
Comment by slee-b on 2020-01-23:
I also tried to get ros_canopen to work and after several days only had basic SDO upload working, and not consistently for some reason. I stumbled on KACANOpen in another post and was able to get up and running quickly with it, like an hour or two. As noted in the accepted answer, it doesnt include baked in ros_control support, but for my application we didnt need it and we got up and running much faster.
Comment by Mathias Lüdtke on 2020-01-24:\
Normally, it should not take that long to setup the basics.
canopen_chain_node
should just enable this from any well-formed EDS/DCF.
If you stumbled upon a bigger problem, please open an issue.
