Hi,
I have recently startet using ros_canopen, but I have a hard time figuring out how it works exactly. Currently I am controlling my robot using socketcan_bridge (socketcan_to_topic and topic_to_socketcan) to just "tap in" on the can bus to read and write using PDO's. I am able to get this to work ok by just setting up the eds files of the motors with appropiate TPDO's and RPDO's.
But I would much rather that I could just set up a canopen node with ros with an eds file and the required RPDO's and TPDO's and the be able to read from the object dictionaries. As i see it I would have to run canopen_motor_node or canopen_402, but Iam using my own driver and not one from ros_control.
I have tried launching the chain.launch within canopen_chain_node using a virtual can bus. But using candump from canUTILS I am not able to pick the heartbeat (or anything else) up. I dont know whether that is because I am using a virtual can bus or something else. I have noticed that the launch doesn't complain if i run it without initializing the virtual bus, so du I have to set the bus up somewhere else than the config yaml? my config yaml:
    bus:
  device: vcan0 # socketcan network
  # loopback: false # socket should loop back messages
  # driver_plugin: can::SocketCANInterface
  # master_allocator: canopen::SimpleMaster::Allocator
sync:
  interval_ms: 10 # set to 0 to disable sync
  # update_ms: <interval_ms>
  overflow: 0
heartbeat:
  rate: 20
  msg: "77f#05" # message to send, cansend format heartbeat of node 127 with status 5=Started
defaults:
  eds_pkg: canopen_chain_node
  eds_file: eds/test2eds.eds
# struct syntax
nodes:
  node1:
    publish: ["60FF"]
So my question is: Is it possible to have a canopen node running, somewhat passively (only being set up with the eds file, but still running with heartbeats and so on) with the canopen_chain_node and/or canopen_master. and if yes how. please forgive me if this seems a trivial question, canopen is entirely new to me and I am also fairly new at programming all in all. but I could really use some help!
Edit: maybe passively wasn't quite the right word to use, what I meant was two things:
  • Is it possible to set up a node that transmits TPDO's as requested, RPDO's , and a heartbeat as set up in the eds file and that also responds to SDO's and NMT's sent from a master or other nodes on the bus.
  • furthermore is it possible to have access to the object dictionary to change values and through that change what values are being sent with the TPDO's.
Thank you for your help! as this would greatly improve my setup.
Re-edit: Thanks for the answer, these are just to features I wanted! However as I am doing quite a bit of my work away from the robot i have set up some test code that uses a virtual can and I cannot get the node to initialize I just get:
success: False
message: could not reset node '1'
and
vcan0  000   [2]  82 01
vcan0  000   [2]  02 01
and
[ INFO] [1510308088.698080279]: Initializing XXX
[ INFO] [1510308088.698592687]: Current state: 1 device error: system:0 internal_error: 0 (OK)
[ INFO] [1510308088.701974798]: Current state: 2 device error: system:0 internal_error: 0 (OK)
[ INFO] [1510308098.703534765]: Current state: 2 device error: system:125 internal_error: 0 (OK)
[ INFO] [1510308098.703622135]: Current state: 0 device error: system:125 internal_error: 0 (OK)
[ INFO] [1510308098.703703969]: Current state: 0 device error: system:0 internal_error: 0 (OK)
[ INFO] [1510308098.703794303]: Current state: 0 device error: system:0 internal_error: 0 (OK)
Is it because I am using a virtual can?
also as this is a bit from the original question, should I open this up as a new question rather than continuing here?
Originally posted by rhas on ROS Answers with karma: 37 on 2017-11-08
Comment by Mathias Lüdtke on 2017-11-08:
Please elaborate on what you consider "passive" and what not.
Comment by Dizett on 2018-02-22:
You can upload your project to https://github.com ? I really appreciate your help with this.
Comment by k5519995 on 2019-06-25:
How you solved this could not reset node '1' ?
If you are using the canopen_chain_node as is, you can:
  • send a SYNC, disable the SYNC, use the SYNC from another master
  • set/read objects with a service; if the data was mapped to a PDO it will be sent via PDO otherwise via SDO
  • send heatbeats
However, you cannot disable the NMT commands, they are hardcoded in canopen_master.
If you need a different behavior, you have to subclass Node. But there is not yet a mechanism to use a subclassed Node in canopen_chain_node.
Feel free to open a GitHub issue for anything that is missing.
Regarding your vcan problem:
As I outlinef above you cannot disable the NMT handling ("could not reset node '1'"). So it seems that device 1 is not present (or emulated). The master cannot reach the slave devices and gives up.
Originally posted by Mathias Lüdtke with karma: 1596 on 2017-11-09
Comment by rhas on 2017-11-10:
Thank you once again for your answer!
Some of my problems was due to me misunderstanding how the canopen_chain_node works. This has been clarified here.
