Hi. I am quite new to ROS . I want to use ros_canopen package to communicate with the robot in my lab, i.e. build a ros controller for it. However , I cant find a more detail tutorial to use it than the general intro on wiki.org .
HardWare and resources:
  1. A USB-to-CAN compact is used to communicate between my laptop and the robot . This USB-to-CAN provids a Linux driver called ECI and an EDS file for configuring CANopen devices.
  2. The robot uses Maxon motors and Copley driver boards(Accelnet Micro Module). Copley provides a Copley Motion Lib(CML).
ros_canopen seems only support socketcan![](http://wiki.ros.org/ros_canopen?
How can I set up my laptop to communicate with CAN bus. I use Ubuntu 14.04 with Indigo installed.
Many thanks.
Originally posted by Craig on ROS Answers with karma: 78 on 2016-05-05
Comment by Mathias Lüdtke on 2016-05-06:
As JuliusGel pointed out, try to install the ixxat socketcan driver: http://www.ixxat.com/support/file-and-documents-download/drivers/socketcan-driver (see the README!). The ros wiki pages on socketcan_interface and canopen_motor_node give some additional hints. Feel free to add what's missing.
Comment by Craig on 2016-05-06:
Thank you for the repaid replies. The ixxat socketcan driver works. Thx again !
So i'm trying to configure canopen_motor_node. Here I found a repo using ros_canopen [https://github.com/jlarraez/schunk_lwa4p/blob/master/launch/robot.launch] . I'm trying to write a launch file to start canopen_motor
with a can.yaml and a node.yaml. However it threw out a canopen::ParseException. Are there other projects that use ros_canopen? Maybe I could borrow some of their codes to launch canopen_motor.
Thank you very much.
Comment by Will on 2016-05-18:
Hi. I'm in the same situation with you. I use the same hardware and have no idea what to do next. Can we communicate by e-mail? I think that is more efficient and will save lots of time. My e-mail address is [email protected]. Look forward to your letter.
Comment by jarvisschultz on 2016-05-18:
Hi @Will... just wanted to let you know that I moved your answer to be a comment. Answers are specifically reserved for answers. Best of luck getting your situation resolved!
Comment by Mathias Lüdtke on 2016-05-19:
The Care-O-bot 4 uses ros_canopen for 27 motors (cob_hardware_config). Some examples can be found in https://github.com/ipa320/canopen_test_utils And schunk_robots works as well.
The ParseException is triggered from errors in the EDS (or bugs in the parser).
I assume you are using this USB-to-CAN device. You are right ros_canopen only supports SocketCAN interface. If you want to use another kernel driver i.e. ECI you will have to implement a custom driver plugin. You could have a look at how socketcan_interface is implemented in ros_canopen here.
That being said it seems that your USB-to-CAN device also supports SocketCAN. The driver is located here. So you could have a look at it.
Another question is does your robot use OpenCAN protocol? If it does not then ros_canopen package might not be suitable for you at all. And even if your robot does support OpenCAN you might have to implement additional profiles because ros_canopen for now only supports basic (301) and motion control (402) profiles. But I can not comment on that more without knowing what robot you are trying to control.
Hopefully that helps to clarify things a bit.
Originally posted by JuliusGel with karma: 433 on 2016-05-06
Post score: 5
This answer sums it up pretty well! The CAN layer can be customized with a can::DriverInterface plugin. If your motor does not support the 402 profile you can provide a canopen::MotorBase::Allocator plugin and reuse the ros_control interfaces of canopen_motor_node.
Comment by Craig on 2016-05-09:
Thx. The socketcan driver you gave did work! Now I'm trying to run the canopen_motor_node.There seems to be some problems in the code. Which branch of ros_canopen would you recommond? Indigo-devel or indigo-release-candidate?
Comment by JuliusGel on 2016-05-09:
I believe indigo-devel should be the most up to date code.
