Hello! I am attempting to run a simulation of a Turtlebot3 package on Ubuntu16.02 Gazebo. Everything seems to be going fine until the last .launch file (which of course is the one that I really want to see the behavior of), where I receive the error ERROR: cannot launch node of type [explore_lite/explore]: can't locate node [explore] in package [explore_lite] .
  • First, I launch roslaunch turtlebot3_gazebo turtlebot3_house.launch.
  • Second, I launch roslaunch turtlebot3_slam turtlebot3_slam.launch slam_methods:=gmapping since my other code is dependent on it. -Then roslaunch turtlebot3_navigation move_base.launch
  • Last, I launch the following which is where I get the previously mentioned error roslaunch explore_lite explore_costmap.launch .
I'd love to be able to use Gazebo effectively, but there's just not much documentation out there that shows how to actually test your own code - just how to bring up Gazebo. Anyway, thanks for reading!
Originally posted by AmateurHour on ROS Answers with karma: 95 on 2018-07-09
Hi @AmateurHour,
Have you installed the 'explore_lite' package? I installed and ran it and it ran without any problems.
sudo apt-get install ros-kinetic-explore-lite
roslaunch explore_lite explore.launch
Originally posted by Pyo with karma: 358 on 2018-07-09
Comment by AmateurHour on 2018-07-09:
Yes... you ran it on Gazebo?
Comment by Pyo on 2018-07-09:
Yes! The execution screen is as follows. https://pasteboard.co/HtIAP5y.png
I did a rosclean purge and rebooted my pc and that seems to have fixed it, thank you!!
