When trying to launch an empty world in gazebo using the command
roslaunch gazebo_worlds empty_world.launch
I encounter the error
Invalid node name [gazeboo/�]: node names cannot contain /
Is there a known fix for this issue?
The full error is:
terminate called after throwing an instance of 'ros::InvalidNodeNameException' what(): Invalid node name [gazeboo/�]: node names cannot contain / Msg Waiting for master Aborted (core dumped) Error [Connection.cc:477] Connection[0] Closed during Read terminate called after throwing an instance of 'boost::system::system_error' what(): Connection reset by peer [gazebo-2] process has died [pid 18337, exit code 134, cmd /opt/ros/groovy/stacks/simulator_gazebo/gazebo/scripts/gazebo /opt/ros/groovy/stacks/simulator_gazebo/gazebo_worlds/worlds/empty.world __name:=gazebo __log:=/home/dhruv/.ros/log/6ed9ee8a-dde5-11e2-a0c6-0026c789069a/gazebo-2.log]. log file: /home/dhruv/.ros/log/6ed9ee8a-dde5-11e2-a0c6-0026c789069a/gazebo-2*.log Aborted (core dumped) [gazebo_gui-3] process has died [pid 18346, exit code 134, cmd /opt/ros/groovy/stacks/simulator_gazebo/gazebo/scripts/gui __name:=gazebo_gui __log:=/home/dhruv/.ros/log/6ed9ee8a-dde5-11e2-a0c6-0026c789069a/gazebo_gui-3.log]. log file: /home/dhruv/.ros/log/6ed9ee8a-dde5-11e2-a0c6-0026c789069a/gazebo_gui-3*.log
Launch file:
Originally posted by sunzun on ROS Answers with karma: 41 on 2013-06-25
Post score: 4
Comment by prasanna.kumar on 2013-06-25:
Did you try changing the node name ? Try re-naming the node name from its current value to something else, just 'gazebo' for instance. And also please update the question with your launch file.
Comment by sunzun on 2013-06-26:
I believe the issue is in the ROS api for the gazebo. I haven't made any modifications to the standard groovy install for gazebo (I'm just attempting to run the launch file that ships with the package). I've posted the launch file.
I would go through the source code myself, but it's thousands of lines of code, and a simply searching for "gazeboo" leads me to believe the issue is not as simple as a typo. Of course, I could be wrong, but I couldn't find where the issue was myself.
Comment by RC on 2013-06-26:
I have the same problem, I hope to find the way to solve this.
Comment by fberger on 2014-04-25:
Did anyone resolve this issue?
Okay, so there's apparently an issue with parsing the input argc/argv arguments when initializing the node in the file
/opt/ros/groovy/stacks/simulator_gazebo/gazebo/src/gazebo_ros_api_plugin.src
I fixed this by explicitly defining the node name in the function
void GazeboRosApiPlugin::Load(int argc, char** argv)
by replacing
ros::init(argc,argv,"gazebo",ros::init_options::NoSigintHanlder);
with
std::mapstd::string,std::string remappings; remappings["gazebo"] = "gazebo"; ros::init(remappings,"gazebo",ros::init_options::NoSigintHanlder);
Probably not the most elegant solution, nor does it actually address the root cause of this issue, but it fixes the problem.
Originally posted by sunzun with karma: 41 on 2013-07-09
Comment by octavian on 2013-08-22:
I had the same issue and tried your suggestion above. Do you perform a 'rosmake -a' afterwards in order to compile?
Sunzun, are there any steps to do after editing the file? Also, are you editing gazebo_ros_api_plugin.src or gazebo_ros_api_plugin.cpp? Your instructions so far haven't gotten it to work for me...
I thought I'd explain Sunzun's solution with a bit more detail.
First edit: /opt/ros/groovy/stacks/simulator_gazebo/gazebo/src/gazebo_ros_api_plugin.cpp
By replacing:
// setup ros related
if (!ros::isInitialized()) {
   ros::init(argc,argv,"gazebo",ros::init_options::NoSigintHandler);
 else
    ROS_ERROR("Something other than this gazebo_ros_api plugin started ros::init(...), command line arguments may not be parsed properly.");
with:
    std::map<std::string,std::string> remappings;
     ros::init(remappings,"gazebo",ros::init_options::NoSigintHandler);
  } else {
It is important to add the brackets around the if and else statement since we now have multiple instructions within the if statement clause.
Now, in order to re-compile the package with the changes, this is perhaps a little bit of a hack but you need to first delete the ROS_NOBUILD file from within /opt/ros/groovy/stacks/simulator_gazebo/gazebo This will tell rosmake to recompile this package.
If you attempt to run rosmake simulator_gazebo, you will get a permission denied error, so now you need to temporarily change the ownership of the simulator_gazebo package.
sudo chown -R %YOUR_USER_NAME%: simulator_gazebo
Now you should be able to run:
And it should re-compile your changes to the file!
Now, run:
and Enjoy!
Originally posted by fberger with karma: 11 on 2014-04-26
