I'm trying to use rosserial on arduino to subscribe to move_group/fake_controller_joint_states and then publish the first joints position on a topic chatter just to test verify that im receiving the position but it seems that the call back is not working as I don't seem to receive the values being sent on fake_controller_joint_states. Im using an arduino mega, kinetic and ubuntu 16.04. I greatly appreciate any direction or input. thank you.
#if (ARDUINO >= 100)
#include <Arduino.h>
#else
#include <WProgram.h>
#endif
#include <ros.h>
#include <std_msgs/Float64.h>
#include <sensor_msgs/JointState.h>
#include <stdlib.h>
ros::NodeHandle nh;
std_msgs::Float64 mydata;
float angle[6] = {0,0,0,0,0,0};
void cmd_cb(const sensor_msgs::JointState& cmd_arm)
angle[0] = cmd_arm.position[0];
angle[1] = cmd_arm.position[1];
angle[2] = cmd_arm.position[2];
angle[3] = cmd_arm.position[3];
angle[4] = cmd_arm.position[4];
angle[5] = cmd_arm.position[5];
ros::Subscriber<sensor_msgs::JointState> sub("/move_group/fake_controller_joint_states", cmd_cb);
ros::Publisher chatter("chatter", &mydata);
void setup()
nh.initNode();
nh.subscribe(sub);
nh.advertise(chatter);
void loop()
mydata.data = angle[1];
chatter.publish( &mydata );
nh.spinOnce();
delay(1);
rostopic info /move_group/fake_controller_joint_states returns:
Type: sensor_msgs/JointState
Publishers:
* /move_group (http://chris-Latitude-3540:40629/)
Subscribers:
* /joint_state_publisher (http://chris-Latitude-3540:41687/)
* /rostopic_5632_1530298559582 (http://chris-Latitude-3540:32869/)
* /serial_node (http://chris-Latitude-3540:44431/)
rosnode info /serial_node returns:
Node [/serial_node]
Publications:
* /chatter [std_msgs/Float64]
* /diagnostics [diagnostic_msgs/DiagnosticArray]
* /rosout [rosgraph_msgs/Log]
Subscriptions:
* /move_group/fake_controller_joint_states [sensor_msgs/JointState]
Services:
* /serial_node/get_loggers
* /serial_node/set_logger_level
contacting node http://chris-Latitude-3540:44431/ ...
Pid: 10725
Connections:
* topic: /chatter
* to: /rostopic_9634_1530306645550
* direction: outbound
* transport: TCPROS
* topic: /rosout
* to: /rosout
* transport: TCPROS
* topic: /move_group/fake_controller_joint_states
* to: /move_group (http://chris-Latitude-3540:40629/)
* direction: inbound
* transport: TCPROS
Originally posted by chris annin on ROS Answers with karma: 58 on 2018-06-29
Comment by jayess on 2018-06-29:
Have you run
to check the topic's subscribers and publishers? You can also run
rosnode info <node-name>
to see what the node is subscribing to.
What about
Comment by chris annin on 2018-06-29:
added this to the question. thank you
Comment by gvdhoorn on 2018-06-30:
Not an answer, but: please note that JointState
msgs are not meant to be used for commanding pose goals, but for reporting current joint states of your robot. Taking fake_controller_joint_states
as input is also not very nice.
Look into FollowJointTrajectory
Comment by chris annin on 2018-06-30:
i appreciate your feedback, what do you mean by "Taking fake_controller_joint_states as input is also not very nice" Is this fopaux or against protocol? This seems to provides exactly what is needed for an open loop robot.
From the documentation:
This is a message that holds data to describe the state of a set of [..] joints. [..] The header specifies the time at which the joint states were recorded.
Controlling joints is done with FollowJointTrajectory
actions. Or at least, that is how it was designed.
Comment by gvdhoorn on 2018-06-30:\
Is this fopaux
I don't know what this means.
