Hi,
I want to shutdown all nodes from within a ros node. ros::shutdown() kills the current node but does not kill the other nodes.
I know that all nodes can be killed using the terminal and through the launch file. But I test if a certain condition is met and only in such a circumstance I want all the nodes to shutdown.
Thanks!
Originally posted by ashwath1993 on ROS Answers with karma: 70 on 2018-05-28
