I'm trying to shut down all Nodes except 1 within a C++ program. Therefore I want to count the number of ROS_Nodes and kill n-2 nodes. ( My_Node and roscore shall still exist). Or is there any other way to do so?
Thanks for your Help
Originally posted by bambucha on ROS Answers with karma: 3 on 2018-04-16
Comment by gvdhoorn on 2018-04-16:
To avoid an xy-problem, it might be good if you could clarify why you want to do this. It might not be necessary.
Comment by bambucha on 2018-04-16:
I need it, because I have to restart Gazebo with another enviroment. But the Linux-Computer is remote controlled to this. Therefore I have to shut down every ROS_Node, except the one which handles the remote.
If you can manage the state of "your node", then would deployment using Docker perhaps be an option? Reusing roscore instances is not necessarily always very stable (left over parameters, etc).
You could use a combination of the Master API and Slave API to do what you want (first retrieve all registered nodes, iterate over them, compare their names and request the ones you don't want/need any longer to shutdown).
See #q271776 (among others) for a question that deals with something similar.
Note: I would recommend to do this by name, not "by number". That seems very brittle.
Also: roscore is not a node.
Originally posted by gvdhoorn with karma: 86574 on 2018-04-16
sorry for the mistake with the roscore and node! And thanks for the post #q271776, I saw this before. My Problem is to understand this. Because I have never used Python before. Thanks :)
Well, it's mostly XML-RPC, so you could do the same thing using C++. It's just that the libraries that are already there are in Python.
Could I ask you to mark the question as answered if/when you feel it has been answered? Thanks.
