Hello,
I have a project where i start gazebo and several other rosnodes.
I want to be able to shut them all down at some point. I have a node that waits for a certain message and then shuts all other nodes down following with a self shutdown call like:
system("rosnode kill NAME_OF_NODE"); // shutdown other nodes
ros::shutdown();                     // shutdown this node
This does work for everything except the /rosout node. The /rosout node always respawns if killed with rosnode kill. What I tried is to start a roscore in the starting programm before the other roslaunch files are executed, and then at the end, when all nodes finished cleanly I kill the roscore with kill all like:
system("roscore &");                 // start roscore
...                                  // starting other nodes with roslaunch
system("killall roscore");           // kill roscore
But this does seem like a dirty way. Is there a better way to do this?
Originally posted by JulianR on ROS Answers with karma: 1 on 2017-06-05
Comment by Akhilesh on 2017-06-06:
Hi @Gieseltrud, try http://answers.ros.org/question/250182/terminate-ros-program/#250224
My solution is to use a launch file to start all the relevant nodes, with the "terminator" node set to required="true". When the terminator node exits, it will trigger all of the other nodes to close if they are using things like ros::ok() to determine if they should keep running. This only works when roscore has been started by this launch file.
Originally posted by Dale McConachie with karma: 91 on 2017-06-07
Comment by JulianR on 2017-06-08:
This does work fine, There still is a red message informing about the Initiating of the shutdown, but I guess that is just how it is.
I manage ROS like this. I put all launch files inside one master "all.launch", and then I start that using the supervisor service, a simple tool for creating daemons. You can install this on Ubuntu with:
sudo apt-get install supervisor
I configure it by creating a file /etc/supervisor/conf.d/myrobot.conf which looks like:
[program:myrobot]
command=bash -c "source /usr/local/myrobot/src/ros/setup.bash; roslaunch myrobot all.launch"
directory=/usr/local/myrobot/src/ros
user=ubuntu
stdout_logfile=/var/log/supervisor-myrobot.log
stderr_logfile=/var/log/supervisor-myrobot.log
autostart=true
autorestart=true
startretries=3
priority=998
stopasgroup=true
Then, when the system boots, it launches all your ROS nodes automatically. If you want to cleanly stop it, you'd run:
sudo supervisorctl stop myrobot
Similarly, to start it, you'd run:
sudo supervisorctl start myrobot
Originally posted by Cerin with karma: 940 on 2018-01-05
