Now when i move the teleop key, i am publishing messages to bothe the turtlesim nodes. I do not want this but i guess by default it is so that the teleop node will publish the messages to all the turtlesim_nodes present.
No, that is not how this works. The teleop node publishes to the turtle1/command_velocity
topic (here), to which all instances of turtlesim_node
subscribe. That is why they all receive the same message.
1 . How can i have multiple turtlesim_node
running but publish only to 1.
Technically, you can't, as publications are not "to" a certain node, but to a topic. Any node can subscribe to that topic, and publications are anonymous. You have no way to specify a recipient.
What you could do however, is use remapping to effectively 'rewire' a node to publish or subscribe to a different topic. You could use this to make one turtlesim_node
subscribe to turtle1/command_velocity
(the default) and the other to turtle2/command_velocity
. Now if turtle_teleop
publishes to turtle1/command_velocity
, only the first turtlesim_node
will receive the messages.
This effectively achieves what you are asking, but do please note the difference: you're still not sending messages "to" a specific turtlesim_node
, you're just making sure that only one of them "tunes in" on the data stream sent out by turtle_teleop
2 . Using rosservice, how can i clear the content of both the turtlesim nodes at the same time ? using rosservice call /clear
clears the default node.
You can't.
In contrast to messages, service invocations are directed to one particular recipient, namely the service provider (or server). In this case most likely the last turtlesim_node
that came up 'claims' the name clear
and responds to calls to the service.
Remapping can help you here as well, but only to make sure the clear
services are reachable for both (or all) instances.
3 . Is it possible to modify its code or there is some understanding problem from my side ?
From the above, it would seem there is no 'need' to modify the code, as remapping seems to solve issue 1, and issue 2 is not possible, even if you'd modify the source.
If you'd still like to take a look, see ros/ros_tutorials/turtlesim. Clone it into a Catkin workspace, build it and be sure to source
the devel/setup.bash
Originally posted by gvdhoorn with karma: 86574 on 2018-04-16
Comment by gvdhoorn on 2018-04-16:
#q203129 might be interesting as some background on how coupled nodes are when they use the different communication patterns supported by ROS.
Comment by aks on 2018-04-16:
@gvdhoorn Thanks for such a quick and effective response. I tried this and this works. Just one thing : How can i remap the topics of the node my_turtle
. By default it always changes that of the turtlesim_node
rosrun turtlesim my_turtle /turtle1/cmd_vel:=/turtle2/cmd_vel
this says couldnt find an executable named my_turtle. When I use the default i.e. rosrun turtlesim turtlesim_node /turtle1/cmd_vel:=/turtle2/cmd_vel
it works for the turtlesim_node
I would recommend you start using launch files. rosrun
can be used -- also with remapping -- but launch files will make this much easier.
Also: try to avoid speccing absolute topic names (ie: remove the leading /
