Hi,
I just got started with ROS, and I bumped into the first wall when I was going through the tutorial in running turtlesim.
After I ran 'roscore', 'rosrun turtlesim turtlesim_node' and 'rosrun turtlesim turtle_teleop_key', it went through the settings fine. However, it is not responding to my keyboard control. I selected the terminal window of the turtle_teleop_key, but no luck.
While running them, I ran rxgraph to see the diagram, but it mentioned that the node communication failed, so I am predicting it's the problem with network setting, but I don't know how to fix it.
I would greatly appreciate for your help.
Thank you.
Originally posted by daikii on ROS Answers with karma: 11 on 2012-10-17
Comment by Harsh2308 on 2017-09-01:
Are you able to move it via manually publishing to the turtlesim_node?
It's hard to help without further information. As a first step, have a look at the network setup page. rosnode info teleop_turtle might also provide some information.
Originally posted by Lorenz with karma: 22731 on 2012-10-17
current program
  • put your mouse cursor on the terminal (which make it the current program to accept keys), and try to move your turtle again.
  • The problem may because you put your turtlesim at the most front, but turtlesim is not the true one to accept keys.
Originally posted by wangzheqie with karma: 11 on 2017-10-03
