I have 3 different nodes : Node2 subscribes to two different topics of same types published by node 1 and node3. Then it does some calculations on these subscribed topics and the publishes to a new topic which is then subscribed by node 3. So basically I want to test looping calculations.
Here is my class definition for node2 which is subscribing to 1 topic and publishing to 1 :
class HeatConduction1 : public rclcpp::Node
public:
explicit HeatConduction1(const std::string & topic_subscriber1,const std::string & topic_publisher)
: Node("heatConduction1")
auto callback =
[this](const std_msgs::msg::Float32::SharedPtr msg_) -> void
heatflow = calculateHeatFlow(heatflow,tempPM1,msg_->data);
tempPM1 = calculateTempPM1(tempPM1, msg_->data,heatflow);
RCLCPP_INFO(this->get_logger(), "I heard from source node the source heatflow: [%f]", msg_->data)
//RCLCPP_INFO(this->get_logger(), "I heard from heatconduction2 node as the tempPM2: [%f]", msg_2->data)
pub_msg = std::make_shared<std_msgs::msg::Float32>();
pub_msg->data = tempPM1;
RCLCPP_INFO(this->get_logger(), "Publishing: '%f'", pub_msg->data)
pub_->publish(pub_msg);
sub_ = create_subscription<std_msgs::msg::Float32>(topic_subscriber1, callback);
// sub_1 = create_subscription<std_msgs::msg::Float32>(topic_subscriber2, callback);
pub_ = this->create_publisher<std_msgs::msg::Float32>(topic_publisher, rmw_qos_profile_default);
Now, how can i modify this code to add another subscriber. Can I pass another argument in the constructor naming const std::string & topic_subscriber2
and then create another shared pointer as sub_1
and use a callback command as sub_1 = create_subscription<std_msgs::msg::Float32>(topic_subscriber2, callback);
But this is not working as it gives a compilation error.
Or should i have another callback function in the constructor and call it seperately ? but in this case how would the callbacks be synchronised ?
Any helps would be appreciated.
Originally posted by aks on ROS Answers with karma: 667 on 2018-05-22
