Hi, I reversed a 2d laser scanner that rotated 360 degrees through a servo motor. Because I turn it backwards, there is a reverse image on the Rviz platform. that is, the ceiling looks like a base, and the base looks like a ceiling.How to fix this problem on the RVİZ. Thanks in advance.
Originally posted by Mekateng on ROS Answers with karma: 85 on 2018-03-05
Please make sure you rotated the coordinate frame about the correct axes. ( z-axes). Seems like you have rotated it about y-axes. Follow the right-hand rule to decide which axes you need to rotate.
Originally posted by Gayan Brahmanage with karma: 929 on 2018-03-05
Comment by Mekateng on 2018-03-06:
Thank you Mr. @Brahmanage . but axis is true.I was spinning the lidar around the z axis. when I turn the lidar 180 degrees, that is, when I do -z I have encountered such a problem. I think I need to do something small in the URDF model, but I do not know.
ı solved my problem Mr. Brahmanage. Thank you. I would like to communicate with you to apply your knowledge about a subject if possible.
