I have built several 3D LiDAR scanners for our lab using the technique you describe. There are a few factors to consider when choosing an actuator:
It needs to be able to accurately
report its position in space and
time. You'll need to precisely
register each 2D LiDAR scan with the
position of the actuator when that
scan was captured, so this position
feedback is very important however
it is achieved.
You'll also want something which
already has good ROS support; nobody
want to re-invent the wheel.
The actuator also needs to be strong
and precise enough to repeatedly
follow exactly the same path, so
that your 3D scans are consistent.
These requirements can be achieved just as well by a stepper motor system or a DC motor with an encoder, but I would recommend avoiding building something from parts if you can.
We use the FLIR ptu-46 for our 3D LiDAR scanners, there is a ROS driver avilable for this too. It's not the cheapest I have to say but it's strong, reliable and has very good position feedback.
Originally posted by PeteBlackerThe3rd with karma: 9529 on 2018-05-18
Comment by Mekateng on 2018-05-18:
Thank you for your answer. However, for example, the resolution of the LİDAR we use is 0.352 degree. The resolution of the actuator we use is 0.2. So much higher. What happens when a situation like this happens?
Comment by PeteBlackerThe3rd on 2018-05-18:
Those two resolutions describe very different concepts, I would say the difference is not that important. The lidar resolution is the angular distance between samples, and the actuator resolution is the precision it can move itself too.
At the end of the day you probably want the same angular distance between 2D line scans as there is between individual LiDAR samples within each line. It sounds like you can achieve this fine with the 0.2 degree resolution actuator, so this should be fine.
