In my project, there are two main computing boards connected to a laptop. The laptop has a master ROS server, and the boards have slave servers. What I want to accomplish is that when boards are turned on, they would automatically launch their nodes while still maintaining the connection to the laptop.
So far I only made a roslaunch file in a host laptop, a file that contains information about machines and nodes to run. And I installed robot_upstart in the host so that ros server as well as the nodes written in the host can be run at startup. So If I want the same thing to happen to the two boards while the three machines stay connected to each other, what should I do?
Thanks for any help.
Originally posted by chanhyeoni on ROS Answers with karma: 62 on 2018-01-26
