Hi all, I am trying to use tf2_ros::Buffer in a simple code. When I put it in the main function, everything works fine. But when put in a class, building error occurs. The code is like this:
#include <ros/ros.h>
#include <tf2_ros/buffer.h>
#include <tf2_ros/transform_listener.h>
#include <geometry_msgs/TransformStamped.h>
#include <geometry_msgs/Twist.h>
class test_class
private:
    double start;
    double duration;
    ros::Time start_time;
    ros::Time end_time;
    std::string robot_name;
    tf2_ros::Buffer tf_buffer; // problem
    tf2_ros::TransformListener* tfListener;
    geometry_msgs::TransformStamped transformStamped;
public:
    std::string space_name;
    std::string node_name;
    test_class()
        space_name = ros::this_node::getNamespace();
        node_name = ros::this_node::getName();
    ~test_class()
    bool initialize(const ros::NodeHandle& n)
        ROS_INFO("Class auto_mav_flight initialized done!");
        return true;
    void timer_callback(const ros::TimerEvent& event)
        ROS_INFO("Timer Callback triggered.");
        return;
int main(int argc, char** argv)
    ros::init(argc, argv, "auto_mav_node");
    ros::NodeHandle node;
    ROS_WARN("The node is initilized and started.");
    test_class amf = test_class();
    amf.initialize(node);
    ros::Timer timer_1 = node.createTimer(ros::Duration(0.5), &test_class::timer_callback, &amf);
    ros::spin();
    return EXIT_SUCCESS;
and the building error information is:
/home/arkin/ros_code/sandbox/auto_mav_sandbox/src/auto_mav_flight/src/node_main.cpp: In function ‘int main(int, char**)’:
/home/arkin/ros_code/sandbox/auto_mav_sandbox/src/auto_mav_flight/src/node_main.cpp:73:44: error: no matching function for call to ‘test_class::test_class(test_class)’
/home/arkin/ros_code/sandbox/auto_mav_sandbox/src/auto_mav_flight/src/node_main.cpp:73:44: note: candidates are:
/home/arkin/ros_code/sandbox/auto_mav_sandbox/src/auto_mav_flight/src/node_main.cpp:26:2: note: test_class::test_class()
  test_class()
/home/arkin/ros_code/sandbox/auto_mav_sandbox/src/auto_mav_flight/src/node_main.cpp:26:2: note:   candidate expects 0 arguments, 1 provided
/home/arkin/ros_code/sandbox/auto_mav_sandbox/src/auto_mav_flight/src/node_main.cpp:9:7: note: test_class::test_class(test_class&)
 class test_class
/home/arkin/ros_code/sandbox/auto_mav_sandbox/src/auto_mav_flight/src/node_main.cpp:9:7: note:   no known conversion for argument 1 from ‘test_class’ to ‘test_class&’
make[2]: *** [auto_mav_flight/CMakeFiles/auto_mav_flight_node.dir/src/node_main.cpp.o] Error 1
make[1]: *** [auto_mav_flight/CMakeFiles/auto_mav_flight_node.dir/all] Error 2
make: *** [all] Error 2
I found that if I comment the code line:
the error disappear.
Why the tf2_ros::Buffer can cause problem of class construction even I just declare it as a member of class?
Any help will be appreciated.
Thanks in advance.
Originally posted by arkin on ROS Answers with karma: 71 on 2017-10-09
For reference: https://stackoverflow.com/questions/46662748/building-error-when-declare-tf2-rosbuffer-in-class
From tf2_ros::Buffer header, it inherits from BufferCore, which contains a boost::mutex(among other things - there could more than 1 non-copyable attribute) which is not copy-constructible. That makes tf2_ros::Buffer not copy-constructible. Since test_class do not define a copy-constructor and contains a non-copyable attribute, the compiler cannot generate a copy constructor and fails to compile when you try to call a copy constructor.
So, the class need a copy constructor to do the class initialization : test_class amf = test_class(); If I replace this code line with test_class amf; it works. Of course it will be necessary to remove the operation of the user-defined class constructor. An alternative way is to define a copy constructor (even an empty constructor) like: test_class(const test_class& right_side). This also solve the problem. It seems that realizing tf2_ros::Buffer not copy-constructibal is the key to solve this problem.
Originally posted by arkin with karma: 71 on 2017-10-11
Comment by gvdhoorn on 2017-10-11:
Could I please ask you to post the answer you got on SO here as an answer as well? We'd like to keep answers here self-contained, to avoid future readers having to click through N links to get to the actual solution.
Thanks.
Comment by arkin on 2017-10-13:
Sure, Thank you. :-)
