I am following this link for installing ROS driver for raspberrypi camera module. But after executing the command sudo ./src/catkin/bin/catkin_make_isolated --install --pkg rosberrypi_cam -DCMAKE_BUILD_TYPE=Release -Draspicam_DIR:PATH=/home/pi/ros_catkin_ws/external_src/raspicam/build/ --install-space /opt/ros/indigo -j2 I am getting this error...
make[2]: *** No rule to make target '/usr/local/lib/libraspicam.so', needed by '/home/pi/ros_catkin_ws/devel_isolated/rosberrypi_cam/lib/rosberrypi_cam/rosberrypi_cam_node'.  Stop.
CMakeFiles/Makefile2:707: recipe for target 'CMakeFiles/rosberrypi_cam_node.dir/all' failed
make[1]: *** [CMakeFiles/rosberrypi_cam_node.dir/all] Error 2
Makefile:138: recipe for target 'all' failed
make: *** [all] Error 2
<== Failed to process package 'rosberrypi_cam':
  Command '['/opt/ros/indigo/env.sh', 'make', '-j4', '-l4']' returned non-zero exit status 2
Reproduce this error by running:
==> cd /home/pi/ros_catkin_ws/build_isolated/rosberrypi_cam && /opt/ros/indigo/env.sh make -j4 -l4
Command failed, exiting.
If anyone has faced the same issue in raspbian Jessie, please help. Thank you.
Do I need to install openCV2 for this ROS package, as the main.cpp files includes certain header files from opncv2, does that indicate that it require openCV in raspbian??????
Originally posted by user_123 on ROS Answers with karma: 23 on 2017-10-06
You need to install the package camera_info_manager in your workspace.
You can do it by following the directions at the end of the ROSberry tutorial http://wiki.ros.org/ROSberryPi/Installing%20ROS%20Indigo%20on%20Raspberry%20Pi with rosinstall.
Originally posted by Nico__ with karma: 36 on 2017-10-06
Comment by user_123 on 2017-10-09:
I tried to install the package camera_info_manager in the ros_catkin_ws using sudo apt-get install ros-indigo-camera-info-manager, but got an error Unable to locate package... Please help regarding installation of camera_info_manager. I have followed the same page of instructions as suggested by you
I could successfully install camera_info_manager and camera_callibration_parsers,after installing them I am getting this error. make[2]: *** No rule to make target '/usr/local/lib/libraspicam.so', needed by '/home/pi/ros_catkin_ws/devel_isolated/rosberrypi_cam/lib/rosberrypi_cam/rosberrypi_cam_node'
Please help with the above problem @Nico__
Comment by Nico__ on 2017-10-12:
Did you follow every steps of https://github.com/japonophile/rosberrypi_cam that you mention on your original post?
