I'm following these steps http://wiki.ros.org/ROSberryPi/Installing%20ROS%20Indigo%20on%20Raspberry%20Pi for installing ROS Indigo on a RPI3. I keep getting this error below when I compile the package. I've applied the two patches that are recommended in the wiki and tried to verify all my dependencies but nothing helped. Please help.
`<== Finished processing package [176 of 188]: 'turtle_tf2'
==> Processing catkin package: 'urdf' ==> Building with env: '/opt/ros/indigo/env.sh' ==> cmake /home/pi/ros_catkin_ws/src/robot_model/urdf -DCATKIN_DEVEL_PREFIX=/hom e/pi/ros_catkin_ws/devel_isolated/urdf -DCMAKE_INSTALL_PREFIX=/opt/ros/indigo -D CMAKE_BUILD_TYPE=Release -G Unix Makefiles in '/home/pi/ros_catkin_ws/build_isol ated/urdf' -- Boost version: 1.55.0 -- Found the following Boost libraries: -- thread CMake Error at CMakeLists.txt:5 (find_package): By not providing "Findurdfdom.cmake" in CMAKE_MODULE_PATH this project has asked CMake to find a package configuration file provided by "urdfdom", but CMake did not find one.
Could not find a package configuration file provided by "urdfdom" with any of the following names:
urdfdomConfig.cmake
urdfdom-config.cmake
Add the installation prefix of "urdfdom" to CMAKE_PREFIX_PATH or set "urdfdom_DIR" to a directory containing one of the above files. If "urdfdom" provides a separate development package or SDK, be sure it has been installed.
-- Configuring incomplete, errors occurred! See also "/home/pi/ros_catkin_ws/build_isolated/urdf/CMakeFiles/CMakeOutput.log" . <== Failed to process package 'urdf': Command '['/opt/ros/indigo/env.sh', 'cmake', '/home/pi/ros_catkin_ws/src/robot _model/urdf', '-DCATKIN_DEVEL_PREFIX=/home/pi/ros_catkin_ws/devel_isolated/urdf' , '-DCMAKE_INSTALL_PREFIX=/opt/ros/indigo', '-DCMAKE_BUILD_TYPE=Release', '-G', 'Unix Makefiles']' returned non-zero exit status 1
Reproduce this error by running: ==> cd /home/pi/ros_catkin_ws/build_isolated/urdf && /opt/ros/indigo/env.sh cmak e /home/pi/ros_catkin_ws/src/robot_model/urdf -DCATKIN_DEVEL_PREFIX=/home/pi/ros _catkin_ws/devel_isolated/urdf -DCMAKE_INSTALL_PREFIX=/opt/ros/indigo -DCMAKE_BU ILD_TYPE=Release -G 'Unix Makefiles'
Command failed, exiting.`
Originally posted by AloshkaD on ROS Answers with karma: 16 on 2016-06-30
Comment by gvdhoorn on 2016-06-30:
Please format console copy/pastes using the Preformatted text button (the one with 101010 on it). That will make this much more legible.
When I checked the dependencies I realized that liburdfdom-dev failed to install and that's probably the issue. I'm trying to fix it and I will post the solution if that was indeed the issue.
Originally posted by AloshkaD with karma: 16 on 2016-06-30
Comment by Nate on 2016-07-07:
I got the same failure. Did you find a fix?
Comment by AloshkaD on 2016-07-07:
Yes I did.I downloaded the liburdfdom-dev and installed it on my system . I had to remove it twice and force install it because I kept getting an installation error.
Hi. Thanks for your reply! When I attempted to sudo apt-get install liburdfdom-dev I then ran into another dependency issue... it was complaining about not having the libconsole-bridge-dev dependency. Did you run into this issue as well? I really appreciate your help.
I ended up doing the same thing you did. I had to remove both liburdfdom-dev and the console-bridge and rebuild both. Thanks again for the pointer!
Glad that helped, I was stuck on this issue for 3 days.
Comment by prat33kg on 2018-02-19:
Hey guys. Can anyone tell me the command used to remove this dependency? Thanks in advance.
