I have installed googlemaps, numpy and polyline using pip install command on ubuntu 16.04. As I run the code using sudo python code.py, it works. But, When I use rospy in code and run it as rosrun package code.py the code doesn't work. It shows problem in connecting googlemap API. I want to include these python packages(googlemaps..) on ROS so that the code works on ROS. How to do it?
Originally posted by amar on ROS Answers with karma: 16 on 2017-06-21
Comment by ufr3c_tjc on 2017-06-21:
Why do you run it with sudo? Do you get errors running code.py without sudo?
Comment by amar on 2017-06-22:
to run a pyhton script i use sudo. Without sudo i get errors as ros can't find the pyhton packages which i installed using pip. I just want to know how to use googlemaps , numpy and polyline on ROS. I want to know how to run the code with these modules using rosrun.
Comment by gvdhoorn on 2017-06-22:
Using sudo
is almost never necessary, and should certainly not be required for starting regular Python scripts that load a few libraries. Did you use a virtualenv to install your libraries? Can you tell us the output of:
$ python
>>> import numpy <enter>
And perhaps also: which python
python- 2.7.12 . I installed those packages using pip install command. I want to run the python script using rosrun so that i can publish data. But when i use rosrun the code doesn't work. using sudo to run the code is not a concern
Comment by gvdhoorn on 2017-06-22:\
it is a concern, as it should not be necessary and seems to point to 'larger' problems with your setup / configuration.
pip
-installed modules should be usable under any account. And should also work 'with ROS'.
Can you tell us what the output is of echo $PYTHONPATH
? Both before and after you have source
d setup.bash
Also: please edit your original question and include the errors that you encounter when trying to run your node using rosrun
. Use the Preformatted Text button (the one with 101010
on it) to format everything properly.
echo $PYTHONPATH results /home/pi/catkin_ws/devel/lib/python2.7/dist-packages:/opt/ros/kinetic/lib/python2.7/dist-packages
