Hello!
I want to give values to a topic with this type of mesage (rosgraph_msgs/Clock)
I create a variable called "reloj" for example:
rosgraph_msgs::Clock reloj;
How do I give a value to that variable?, because it has two parts (secs and nsecs)
For example in float64 I give it the value this way
std_msgs::Float64 variable;
variable.data = 0;
I would like to do the same but in rosgraph_msgs/Clock, one value for "secs" and one for "nsecs"
I tried: reloj.clock.secs = 1; reloj.clock.nsecs = 100;
reloj.clock_secs = 1; reloj.clock_nsecs = 100;
But this does not work
I found that putting the following does work
reloj.clock = {5,88};
but when creating the node executable, I get this warning:
warning: extended initializer lists only available with -std=c++11 or -std=gnu++11 reloj.clock = {5,88};
I use ROS kinetic and roscpp (c++)
this is the code in c++
#include "ros/ros.h"
#include "rosgraph_msgs/Clock.h"
ros::init(argc, argv, "pubsubclock");
ros::NodeHandle n;
ros::Publisher publicador;
publicador = n.advertise<rosgraph_msgs::Clock>("topico_pub", 1000);
ros::Rate loop_rate(10);
while (ros::ok()) {
publicador.publish(reloj);
ros::spinOnce();
loop_rate.sleep();
return 0;
thank you very much
Originally posted by manupe94 on ROS Answers with karma: 1 on 2017-04-24
Comment by gvdhoorn on 2017-04-24:\
that doesn't tell us very much. Please explain what you found that "does not work". Include any error messages that you get.
Please use the edit
button/link to update your original question.
Comment by manupe94 on 2017-04-24:
I updated the message
Comment by Geoff on 2017-04-24:
The syntax reloj.clock = {5,88};
is a form of constructor calling that is new in C++11. You cannot use it without telling the compiler to compile in C++11 mode.
